Old 20th October 2011, 06:40 AM   #1
Default I love jfet input
Heres another one of my ideas for a amplifier with jfet input and a frequency response flat from dc to 1MHz.
I'm bold enough to call this one a HIGH END(a wire with gain) kinda poweramp even though its a rather standard circuit:
http://i.imgur.com/PjwPsh.png
http://i.imgur.com/ZeWnvh.png
The point of life is to build atleast one audio amplifier before you die.
Old 20th October 2011, 07:37 AM   #2
Some loop gain stuff:
http://i.imgur.com/RdxSgh.png
http://i.imgur.com/ZKyLDh.png
Old 20th October 2011, 10:37 AM   #3
Would you be prepared to post a more detailed schematic so that we can share component values and types?
regards Andrew T.
Old 20th October 2011, 01:23 PM   #4
Heres a larger and also updated version:
http://i.imgur.com/xDqfi.png
Old 20th October 2011, 01:47 PM   #5
dadod is offline dadod  Croatia
dadod's Avatar
THD20k with 21ppm. Could you show FFT?
Here is JFET input too, look at the link:
ThermalTrak+TMC amp
dado
Old 20th October 2011, 02:02 PM   #6
No i cannot show a FFT because i cannot get that part to work properly, and i set my spice directives to not visible to get the window smaller, so i can no longer change any of those settings.
Old 20th October 2011, 02:33 PM   #7
dadod's Avatar
You don't need to change anything, just click with right mouse button on Voutput diagram and then choose View and then FFT.
dado
Old 20th October 2011, 02:35 PM   #8
And all i get is a line with a stair step down to a lower level.
Old 21st October 2011, 07:20 AM   #9
Heres something that has me stumped, the amp is not unstable with signal, but it is during startup, see the red ring:
http://i.imgur.com/qKIfe.png
Old 21st October 2011, 07:57 AM   #10
i think it probably has to do with C1 and/or C8, for now ;p
i suspect C1 most direct. what happens if you make it 47µ?
i'd like to add that it most likely does not show up like that in the real,
and, that c6 and c9 might need a resistor involved somewhere, basestopper perhaps or maybe
between each collector-capacitor node and the powerrail, very low value (could try).
Complementary JFET-JFET cascode input, BJT VAS-Drivers, Lateral Output Neutrality Solid State 53 23rd October 2011 06:53 PM
FS: PreAmp with Complimentary JFET Diff input & JFET ouput USAcircuits Vendor's Bazaar 12 21st June 2011 11:02 AM
Aleph Mini with JFET input? Arie Pass Labs 11 21st March 2008 05:42 PM
discrete jfet input opamp rubydac Solid State 5 12th March 2008 04:59 PM
JFET input SuSy Chipamp Russ White Pass Labs 4 7th May 2007 08:12 AM
Page generated in 0.10643 seconds (70.29% PHP - 29.71% MySQL) with 10 queries
