Old 19th October 2011, 06:40 AM   #1
Default High power subwoofer amplifier
Heres a sketch for a high power subamp i plan to build just for fun:
http://i.imgur.com/WMYI3.png
The point of life is to build atleast one audio amplifier before you die.
Old 19th October 2011, 07:39 AM   #2
Looks good, but the part numbers on the circuit are hard to read. Could you give us a large version?
The placing of the compensation caps around the pre-drivers is not something that is seen everyday, but if it works then it works.
Old 19th October 2011, 09:40 AM   #3
Without them i had a small sub millivolt oscillation in the simulation.
Heres a larger version of the schematic, the output transistors are MJW21195 and MJW21196 but i don't have simulation models for these yet.
http://i.imgur.com/xJHfp.png
Old 19th October 2011, 10:20 AM   #4
Bensen is online now Bensen  Belgium
Bensen's Avatar
Be carfull with the power simulation.
You have to devide the power by 2.828 (2x 1.414) if you want to have the rms power, LTspice is using maximum voltages and maximum currents.
Old 19th October 2011, 10:38 AM   #5
Yes i know and my power supply is rated at 500VA so 300W RMS is the max practical output power if even that.
Old 19th October 2011, 05:07 PM   #6
Nico Ras's Avatar
Why 2.828. it is simply 2;
√2 x √2 = 2 not 2.828
Kind regards
Nico
Old 19th October 2011, 05:11 PM   #7
Nico Ras's Avatar
This amp will clip due to your transformer running out of gas. If you had an +800VA you would be looking more at 560 watt "rms" into 4 Ω resistive load.
Kind regards
Nico
Old 19th October 2011, 05:16 PM   #8
Bensen's Avatar
Indeed, you're right!
Old 19th October 2011, 05:16 PM   #9
Atleast it clips before the SOA of the outputs is exceeded. And i will never ever reach anywhere near clipping anyways, any of my amps are lucky to make it past 5 watts as i live in a apartment.
I don't use a sub in my system so this build is only for fun, just like all my other projects.
Old 19th October 2011, 06:31 PM   #10
Nico Ras's Avatar
You are well inside the SOA.
Kind regards
Nico
How high does the Bash 300W subwoofer amplifier extend? Defo Multi-Way 6 1st October 2011 08:15 AM
High Voltage BjT's for Pre-driver stages of High Power Amplifier - Overview tiefbassuebertr Solid State 38 30th May 2011 07:37 AM
Searching for schematics: any high power class D subwoofer amp J.R.Freeman Car Audio 11 20th June 2010 03:13 AM
High Power Subwoofer - Jamo SW 505e EDAT Swap Meet 0 15th January 2004 06:25 PM
Page generated in 0.11004 seconds (76.95% PHP - 23.05% MySQL) with 11 queries
