Old 18th October 2011, 05:58 PM   #1
Default Another Crown 602
Hello everyone, I'm new to this particular forum, but have many years experience on repair & installation of audio & video electronics, in the broadcast industry.
I took on a Crown XLS 602 for a friend, thinking that it would be like Amcron amplifiers I used to work on, however having read most of the relevant existing info I now know different...
The one in my posession is exhibiting all the signs of s/c output devices, except that they are not! Powering up just leaves the PTC on the soft start getting hot, as obviously there is a problem, so the relay does not close. Disconnecting the mains TX HV secondary from the bridge, results in all the earlier stages coming to life.
There are no measurable shorts on the HT rails at all.
Presumably something is turning hard on once HT is applied.
The correct circuit diagram would help, the ones I have seen do not exactly match the unit I have, which was manufactured in 2007.
Before I get the variac out, has anyone experienced anything similar?
Thanks,
David.
Old 18th October 2011, 06:32 PM   #2
pinkmouse's Avatar
Hi David, the one I had I recycled as it was just too much effort to fix!
That aside, if the outputs seem fine, the first thing I'd check would be the protection circuitry, starting at the output relays and working back. If that all works, then it's down to pulling and testing transistors I'm afraid.
The schematic I have has drawing number C1071-6 if that's any use.
Al
I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort
Old 18th October 2011, 06:32 PM   #3
Check here, might be of help to you.
Discontinued Amplifier Products
Best of luck to you. John
Old 18th October 2011, 07:00 PM   #4
Thanks both, for such a speedy reply, much appreciated. I am most impressed!
The 602 appears to be a current product, so unfortunately, the relevant cct diagram was not there, in the discontinued product page.
It sounds as though I will as you suggest, have to work my way through the "protect" circuit, which was what I had initially thought when I first started on this beast.
Al, I would appreciate the diagram you mention, it may be relevant.
Thanks again,
David.
Old 19th October 2011, 01:10 AM   #5
djk is offline djk
djk's Avatar
Crown will send you the schematic for current product if you request it, Kevin sent me one this morning.
Kevin B Gring
Field Support Technician
Crown Audio
1718 W Mishawaka Rd
Elkhart, In 46517
Phone: 574-294-8006
Toll Free: 800-342-6939
Fax: 866-762-2862
Email: kevin.gring@harman.com
Web: HARMAN - Premium audio and entertainment for automotive, home, and professional. Speakers, amplifiers, headphones, microphones, home theater and personal audio.
www.crownaudio.com
Candidates for the Darwin Award should not read this author.
Old 19th October 2011, 09:11 AM   #6
Thanks very much indeed, I will try contacting Kevin, again - I had previously sent an email but as yet had no reply.
Have now taken out the main PCB, & definitely no s/c on any of the output devices, so am pursuing the protection circuit , which will no doubt be easier with the correct schematic.
Thanks again to all who have replied, much appreciated.
David.
Crown XLS 602 MaitreG Solid State 36 13th October 2011 02:34 AM
Crown 602 XLS Power Issue msquicc Solid State 10 14th June 2011 10:51 AM
Crown XLS 602 service manual stevep314 Solid State 4 25th April 2010 10:02 PM
crown xls 602 galush Parts 1 4th June 2009 01:40 PM
crown xls 602 amp galush Solid State 0 6th April 2009 04:41 PM
Page generated in 0.09555 seconds (76.99% PHP - 23.01% MySQL) with 10 queries
