Old 17th October 2011, 04:37 PM   #1
emmi is offline emmi  India
Default Replacement for 2N3773
Any Replacement for 2N3773 transistor?
Old 17th October 2011, 05:58 PM   #2
khalsa is online now khalsa  India
Send a message via Yahoo to khalsa
2sc5200 TOSHIBA
Old 17th October 2011, 06:09 PM   #3
sbrads is offline sbrads  United Kingdom
You could try trawling the list this site gives on a search..........
2N3773 Transistor Datasheet. Equivalent transistors for 2N3773 - Parameters and Characteristics. Electronic Component Catalog.
I've heard that the 100v SOAR performance was 100% guaranteed with 2n3773s though, and that's a rarity.
Old 17th October 2011, 07:24 PM   #4
The 2SC5200 is a good match electrically, but not mechanically as the cases are very different.
How about the MJ15003? It also comes in a TO3 and the pins are the same. It's billed as Vceo 140V, Ic 20A, Pd 250W, hfe 25-150, fT 2Mhz. The numbers for the 2N3773 are 140V, 16A, 150W, 15-60, fT not stated. Looks like a good match.
The MJ802 could also work. Its only 100V, but the rest looks good at 30A, 200W, 25-100, 2Mhz. If your circuit runs off 40V or below rails you will be OK.
Old 17th October 2011, 08:29 PM   #5
tiefbassuebertr's Avatar
check out 1) and 4) (the TO-3 versions) by post#1 about
bipolar (bjt) transistor families for audio power output stages
possibly a re-design is necessary (independend of the application resp. the kind of use - please note the higher values for Ft).
Old 18th October 2011, 02:54 AM   #6
blmn is offline blmn  Brazil
blmn's Avatar
Is really necessary to replace the transistor?
At Farnell India you can find good 2n3773 from many manufacturers:
Transistors - Bipolar - (BJT) Single | element14 India
Old 18th October 2011, 03:59 AM   #7
DigiKey will sell them for $3.04 and has 811 of them. Are you asking for improved devices?
Old 18th October 2011, 11:18 AM   #8
AndrewT is online now AndrewT  Scotland
The 5200 gets no where near the cold, nor the hot, SOAR performance of the 3773.
It cannot be a replacement where SOAR has been used by the designer.
regards Andrew T.
Old 18th October 2011, 01:03 PM   #9
For SOAR performance, check out the MJ21194. The datasheet gives 2.5A, 80V for one second.
Other numbers are Vceo 250V, Ic 16A, Pd 250W, hfe 25-75, fT 4MHz. Might be the one to go for, but the high-ish fT _could_ be a problem in some circuits (strange as it may sound).
Old 18th October 2011, 02:21 PM   #10
jez is offline jez  United Kingdom
Why replace it? They are easy to get and cheap.
Repairs and mods to Real Hi-Fi, guitar amps and P.A. in North East England. http://www.arklesselectronics.com
Pass amp with 2n3773? Tazzy Pass Labs 12 26th May 2011 02:30 AM
A simple stereo Amp aroud a 2N3773 mjarve Solid State 23 24th May 2011 04:08 PM
Fakes Toshiba 2N3773 photos ? aldovan Solid State 61 12th May 2011 05:47 AM
Fake onsemi 2N3773 Tekko Solid State 13 26th December 2010 09:15 PM
help with replacement tweeter replacement - KLH twenty three indianajo Multi-Way 2 15th February 2010 12:54 AM
Page generated in 0.10813 seconds (79.23% PHP - 20.77% MySQL) with 10 queries
