Complementary JFET-JFET cascode input, BJT VAS-Drivers, Lateral Output
Old 21st October 2011, 12:22 PM   #51
If that is a workable solution that does not blow up, then surely distortion is of secondary concern.
I'm not saying the the extra BJT and components is the only solution, it just occurs to be as a possible solution.
regards Andrew T.
Old 21st October 2011, 12:38 PM   #52
Neutrality is offline Neutrality  Denmark
I know. It might end up being the best solution. Slightly higher THD-20 is something I can live with.
Old 23rd October 2011, 07:44 PM   #53
dodo is offline dodo  Poland
Isn't true the rule of thumb ( based on Borbley jfet infos)
Vgs of the uper j-fet cascoding device (sk246 ) must show at least 2V at the bias level complementary differential input jfet pairs (sk170/sj74)
in your case sk246 /sj103 must show at least 2V vgs on Id=2,5mA ?
Old 23rd October 2011, 07:53 PM   #54
Eagle library.
Old 30th September 2015, 07:08 PM   #55
rhythmsandy is offline rhythmsandy
Finally did you build this amplifier?
Are there any lateral mosfet drivers?
Old 1st October 2015, 02:32 PM   #56
Yes.
regards Andrew T.
Old 1st October 2015, 03:31 PM   #57
which are the lateral mosfet drivers?
Old 1st October 2015, 05:31 PM   #58
use google or your preferred search engine.
regards Andrew T.
Old 1st October 2015, 05:48 PM   #59
what are the problems when using Lateral mosfet for VAS stage?
Old 1st October 2015, 06:03 PM   #60
Read JLH for FET VAS stage
or Borbely for all FET amplifiers.
regards Andrew T.
Complementary JFET-JFET cascode input, BJT VAS-Drivers, Lateral OutputHide this!Advertise here!
JFET input, MOSFET VAS, LATERAL output = Perfect!! lineup Solid State 2377 18th January 2018 04:13 AM
JFET input, MOSFET VAS, VERTICAL output kees52 Solid State 14 6th March 2012 08:56 PM
How about a JFET input, TUBE VAS+buffer, and MOSFET output? mtlin12 Solid State 12 29th August 2011 07:03 AM
Lateral output amp with jfet input Tekko Solid State 2 4th August 2011 07:43 PM
Complementary diff input with JFET and BJT cascode Bensen Solid State 126 16th October 2006 06:35 PM
