SYMEF amplifier
SYMEF amplifier
Old 5th February 2013, 07:13 PM   #931
VT67 is offline VT67  Belgium
VT67's Avatar
This is where am at with both PCB's.
Still waiting for some parts.
Old 8th February 2013, 10:47 PM   #932
pinnocchio is offline pinnocchio  Canada
pinnocchio's Avatar
Can anyone point me to the Bias adjustment procedure of the Symef type 1?
Do
PREAMPs : Bal AMB α10 + JC-80 | Bal DCB1 | Bal LDR3x | AMPs: AMB β24 | USSA3 & 5 | FO v1.4 | TGM8 | VZ Audio NS OPS | NX Amp | FC-100
DACs : TPA Buffalo II + OPC's NTD1 I/V | JLsounds | Mirand AK4490 + Discrete Output Speakers : Troels Gravesen ATS-4 | Sagwee LT V3
Old 8th February 2013, 11:02 PM   #933
billyk is offline billyk  United States
billyk's Avatar
Still waiting... output transistors on back order still. Don't want to start till I have everything I need. Grrrrr
Old 8th February 2013, 11:40 PM   #934
routhun is offline routhun  United States
For Bias settings check post #822. Set the bias trimmer all the way back to counter clock wise, and rotate slowly clockwise until the voltage across R14 (any of the emitter resistors of outputs) to 23mv. Increase the bias slowly in steps of 5mv at a time monitoring the temperature of the heat sinks. You would like to wait around 2min for each step this gives some time for the amp the settle down the bias currents.
If you are powering up for the first time, set the bias trimmer to Counter Clock Wise and use a series light bulb in series with mains or 10ohm 1/4W resistors in series with DC power supplies to the amp. If there are any issues this will prevent the damage of output transistors.
Hope this helps.
routhun
Old 9th February 2013, 01:43 AM   #935
pinnocchio's Avatar
Thanks guys for the quick reply!
Harrison, you will be happy... After almost a year, I've finally managed to finish the amp modules completely!
They're both playing music right now as burn in. Will test shortly.
Ciao!
Do
Old 10th February 2013, 04:55 AM   #936
pinnocchio's Avatar
I finally did most of the burn in and decided to hook it up to my DCB1, Wolfson DAC and Astasia speakers. I'm really impressed by the musicality of this amp and the overal tonal balance. Female voice are really well rendered. Lots of breathing room between instrument and the soundstage has a very good width but maybe not as deep as my ML-2 or B24.
I might just go for the new version of the amp and see if there is improvement. Anyone can comment on the newest PCB design (sound signature)?
Do
Old 10th February 2013, 12:22 PM   #937
VT67's Avatar
This is how far I've got with both boards, still waiting for some parts.
Old 10th February 2013, 12:32 PM   #938
bambadoo is offline bambadoo  Norway
Looking good
Old 10th February 2013, 12:36 PM   #939
VT67's Avatar
@pinnocchio
Does the amp generate much heat?
Old 10th February 2013, 02:37 PM   #940
pinnocchio's Avatar
Nice soldering skills!
Good work
Do
SYMEF amplifierHide this!Advertise here!
Questions about how to decrease the PASS A-40 amplifier into a class AB amplifier. novtango Pass Labs 4 14th February 2018 05:11 PM
Wanted: DIY amplifier builder with experience. I need a 0.7 ohm stable amplifier Audiophilenoob Swap Meet 34 16th May 2005 11:58 PM
