Old 14th January 2013, 06:43 PM   #901
Default Free PCBs
Yes am giving away 50 free PCBs right away , check them out here 50 Free SYMEF PCBs
www.harrisonaudiolabs.com
Old 16th January 2013, 06:26 PM   #902
Thank you for all of you who have joined this adventure . Share with us your build progress and pictures. .
Once finished provide your reviews as SYMEF gently whispers those first notes and probably sweeps your heart away
Then let us know, in your own ears...what you think
Old 18th January 2013, 04:19 PM   #903
billyk is online now billyk  United States
billyk's Avatar
Alrighty then...
Could not find BOM for the new PCB that just arrived. They say type 2 on them and although there is a section for them on the website, there is nothing in the BOM part. I took the BOM from the Type 1 section and converted it to the Type 2 board. All of the part numbers now match the part numbers as listed on the PCB.
So, are the parts the same for both BOMs if their values match? There are two parts missing, C8 a 220uf that looks to be electrolytic and R32 a 7.5, I would assume R. Would someone care to specify those parts? If all this is correct I would be happy to share.
Old 18th January 2013, 05:14 PM   #904
Originally Posted by billyk View Post
Alrighty then...
Kindly share , your assumptions so far seem spot on
Old 18th January 2013, 05:39 PM   #905
billyk's Avatar
OK C8 and R32 still need to be speced out.
I added current prices from Mouser and DigiKey. Also have the BOM as specified saved at both if anyone wants them...
Also can email SS as they don't allow XLS attachments.
Old 18th January 2013, 07:50 PM   #906
Thanks Billy. Will go through it. Note the ground isolation resistor can be a jumper or a 7.5 ohm resistor. C8 on type2 is really C1 on type1
Old 19th January 2013, 07:04 PM   #907
Maros is offline Maros  Netherlands
I got my PCB's! :-)
They are really nice!
Would it be problematic if I'd use a 44VAC transformer (so around 60VDC) in the power supply?
Old 22nd January 2013, 12:15 PM   #908
billyk's Avatar
Parts for the PCBs are on order. Unfortunately the diodes (D5,6) and one of the outputs (Q4) are on back order until late Feb. Need to get the PSU stuff together now. Not real clear on just what I am going to do here tho...
Old 22nd January 2013, 09:26 PM   #909
Originally Posted by Maros View Post
I got my PCB's! :-)
Thank you. +/- 60 VDC is too high, safely +/- 40 VDC , max +/- 50 VDC
Old 22nd January 2013, 09:30 PM   #910
Nice going Billy, you can try two PSU s
1. The one on the site
2. Power Supply Resevoir Size (Thats if you like to experiment )
Wanted: DIY amplifier builder with experience. I need a 0.7 ohm stable amplifier Audiophilenoob Swap Meet 34 16th May 2005 11:58 PM
Questions about how to decrease the PASS A-40 amplifier into a class AB amplifier. novtango Pass Labs 2 21st October 2002 01:50 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
