SYMEF amplifier
SYMEF amplifier
Old 14th September 2012, 08:37 PM   #821
Samuel Jayaraj is offline Samuel Jayaraj  India
Originally Posted by bambadoo View Post
Houston we have sound..
I have not checked bias..
How to do this?
Stop listening to music through the amp and before you go further with anything, set to appropriate bias current through the output stage and check for output offset.
Sam
Old 14th September 2012, 08:47 PM   #822
OnAudio is offline OnAudio
OnAudio's Avatar
Nice pic. Big speakers. How many mV did you use of bias ? Yes it is possible you might need bigger sinks
Set bias by having 23mV across R14.
onaudio.herokuapp.com
Old 14th September 2012, 09:05 PM   #823
bambadoo is offline bambadoo  Norway
No sensitivity control...
Thanks ... Hmm I think I have read that before
Hmm - Which one of the big whites is R14 again?... Unable to see the printings on the pcb.....after completed and brainmalfunctioning...
Old 14th September 2012, 09:58 PM   #824
OnAudio's Avatar
Measure any of them
Old 14th September 2012, 10:03 PM   #825
Approx 3-5mv was it.. on one channel. Have to check with 2 multimeteres I guess.... Will disconnect all and do some bias adjustements.
To turn from tube stuff to transistor stuff is a bit new for me..
Old 14th September 2012, 11:29 PM   #826
OnAudio's Avatar
I do hope you like your excursion into transistor stuff . Do give us a thorough review once you set the bias and are just relaxing enjoying some classics . You do own some pretty pieces from those speakers to the preamps.
Old 15th September 2012, 08:18 AM   #827
................ Which one of the big whites is R14 again?... ..............
Originally Posted by OnAudio View Post
Measure any of them
measure the Vdrop on all of them. Compare the readings to see how good the matching of the source currents are.
One device that passes more current will run hotter. This could be too much if you run the amp hard.
You should be aiming for the same source current for all the amplifier output devices. That's why you match the resistor resistances and match the output transistors.
regards Andrew T.
Old 15th September 2012, 11:33 AM   #828
EDIT:: Since all of this is quite new for me some basic questions will come from this fellow..
If wee look underneath the board - counting from left to right we got 4 measurepoints. Call them 1-4
A pic is added.
My measurements. (after a bit adjustement)
Right channel:
1 - 21.5mV 2 - 25.8mV 3 - 23.4mV 4 - 23.8mV
Left channel:
1 - 22.1mV 2 - 25.6mV 3 - 22.4mV 4 - 25.9mV
Is this ok or not?... Which value should I settle on...
Old 15th September 2012, 12:37 PM   #829
Originally Posted by evette View Post
Make r18=1.8k watch your swing into the drivers. Your hum problem could be you might have to lift the input gnd by a 10 ohm resistor. Evette
Hi there. Has anyone experience with this? Lifting the input gnd by 10ohms. What is the meaning of this?
Where in the schematics should a 10ohm resistor be placed then?
http://www.harrisonaudiolabs.com/Amp...YMEF/SYMEF.pdf
hmm - feels like I have endless with tiny questions
It is natural since this amp plays ridiculously good and I would like to be able to use it with my setup..
So it needs to be hum free and I really need to lower the gain in a way or the other...
Tumbs up soundwis..
Burn in time..It has played about an hour now.. Only new unused components. Can I expect something regarding that issue also?
Old 15th September 2012, 03:54 PM   #830
alex mm is offline alex mm  Romania
alex mm's Avatar
@bambadoo...... just a hint , place C5 and C12 between B and C of transistors not between B and ground like it is in schematic ....
Regards Alex.
SYMEF amplifierHide this!Advertise here!
Wanted: DIY amplifier builder with experience. I need a 0.7 ohm stable amplifier Audiophilenoob Swap Meet 34 17th May 2005 12:58 AM
Questions about how to decrease the PASS A-40 amplifier into a class AB amplifier. novtango Pass Labs 2 21st October 2002 02:50 AM
