SYMEF amplifier - Page 80 - diyAudio
Old 4th September 2012, 03:44 PM   #791
Nico Ras's Avatar
Hi Routhan,
kindly would you take a measurement of a 100 Hz and 20 Hz square waves, this may give some indication of the low frequency response.
Kindest regards
Nico
Old 5th September 2012, 04:13 AM   #792
routhun is offline routhun  United States
Hello Mr. Nico,
I couldn't take the measurements tonight, I'll capture them in a day or 2 and post here.
Thanks,
Routhun
routhun
Old 5th September 2012, 03:10 PM   #793
Join us for an exciting adventure. Put your ears to the test.(Your feedback is really needed) Tell us all about it and advance the state of the art. Join us for round 2. http://www.diyaudio.com/forums/group...oup-thing.html
Old 5th September 2012, 03:48 PM   #794
Nico Ras's Avatar
Hi Harrison/Routhun,
the test I am proposing is not to show up anything bad in the amplifier, I would not do that. What I am suspecting is that the low frequency strain on the power supply would be exactly what is being discussed in the reservoir capacitor thread and what looks like 20 000uF/rail on the photo.
The only reason I asked for the test is that it seemed that routhun was already set-up to do another test. If you have already closed up routhun then do not bother, we will catch someone else who may be about to test an amp.
Kindest regards
Nico
Old 5th September 2012, 03:54 PM   #795
Nico Ras's Avatar
Originally Posted by routhun View Post
Hello Mr. Nico,
Thanks,
Routhun
Hi Routhun, if the square wave test shows bad results do not try and solve it, just show us. I am very keen to see how the reservoir caps rail hold up in a real test. Remember that the test must be into a load else the test is useless.
Kindest regards
Nico
Old 5th September 2012, 05:16 PM   #796
Hi Nico,
Power supply reservoir capacitors are 18000uf,50v panasonics. The total capacitance in this amp is 72000uf for both the channels. I am measuring the waveforms with 8 ohms pure resistive load connected to the output. Any case I'll measure and upload the results soon.
Thanks,
routhun
Old 5th September 2012, 05:30 PM   #797
Nico Ras's Avatar
Hi Nico,
Thanks,
Hi Routhun,
It will definitely be interesting to see the output waveform with so much capacitance per rail.
Would maybe support Gootee's forecast that under power supply stress conditions there may not be enough time to recharge the capacitors. Besides it would be of as much interest to your fellow SYMEF constructors. Thanks for participating Routhun.
Sorry for highjacking your thread Harrison.
Kindest regards
Nico
Old 8th September 2012, 04:34 PM   #798
Default SYMEF measurements
Hi Nico,
Here is the square response of SYMEF at 20hz, 100hz, 10khz and 20khz into 8ohms pure resistive load.
routhun
Old 8th September 2012, 06:59 PM   #799
Nico Ras's Avatar
Thank you very much Routhun. I trust that you found this low frequency response both unexpected and puzzling. However, your scope is on AC coupled please use DC coupled else the effect is accentuated by the probes high pass filter. I would like to see your power supply's effect on the low frequency.
Kindest regards
Nico
Old 9th September 2012, 01:16 AM   #800
Default SYMEF measurements with DC mode
Hi Nico,
Thank you for correcting me it was my mistake, I was using the AC input mode thats why square wave response is not great at lower frequencies. Now I measured again with DC input mode, now the response looks much better.
Thanks,
routhun
Wanted: DIY amplifier builder with experience. I need a 0.7 ohm stable amplifier Audiophilenoob Swap Meet 34 16th May 2005 11:58 PM
Questions about how to decrease the PASS A-40 amplifier into a class AB amplifier. novtango Pass Labs 2 21st October 2002 01:50 AM
Copyright 1999-2017 diyAudio
