#41 | |
whatever gives the result and they look better too only moderate classAB no problem some say metal house small signal devices sound better too others will probably say its a rubbish myth did you do the checkout by building/listening, simulation, or specsheet ? just curious |
#42 |
i have used different casing for the output transistor.goodluck to your amp.
cheers, joel |
#43 | |
If there is excessive bowing then being the outside faces access to modify machine them is easy. |
#44 | |
You v done the Bias and the output network slightly differently. I do hope you enjoy what you hear. Keep thread up to date with your progress. I am targeting at-least 30k builders. Then we will go world wide
#45 |
I am using a formula that will be published soon. This formula has a very high level of accuracy. That is why I am giving these schematics to the diyaudio community as references to good sound. If the formula is wrong well I will have feedback from the diyaudio community, then we can use the feedback to improve the product. I am hoping to demo the products at at-least one of next years audio events.
#46 |
#47 |
I am sure that you can be less vague and give some objective away with regard to the formula. I think throwing you overboard may be necessary after all. OR you can share my ugly women in the dark. Now which would it be?
Kindest regards Nico |
#48 |
#49 |
#50 |
I agree we need a reserve of 3times the current for the speaker in relation to a resistor of the same impedance for some program material. With this in mind then, the amplifier is better suited for 100Watts 4 Ohms.
| Wanted: DIY amplifier builder with experience. I need a 0.7 ohm stable amplifier | Audiophilenoob | Swap Meet | 34 | 16th May 2005 11:58 PM |
| Questions about how to decrease the PASS A-40 amplifier into a class AB amplifier. | novtango | Pass Labs | 2 | 21st October 2002 01:50 AM |
