#31 | |
It depends on where you want to cut your low high frequency roll off ........Adjust to your tastes ![]() Thanks. |
#32 |
There are those that wanted this mod
#33 |
....... first PCB for SYMEF rev1.0
Alex. Last edited by alex mm; 3rd November 2011 at 11:58 PM. |
#34 |
thats a good looking board
regarding onboard supply caps what happens with those thin ground lines when output draws current ? |
#35 |
.....thanks, supply caps are the second filter ,and those thin lines can handle 6.2 Amps each ,as shown in pic below.
![]() Alex. |
#36 |
#37 |
I have nothing against the output devices
but they will need 90degr angled alu profile which will never be a smooth fit to heatsink heat transfer will be compromised apart from the other difficulties of drilling, mounting, pads, etc etc |
#38 |
..... and second PCB rev 1.1 for same schematic ......
output transistors can also be connected with wires without problems Alex. Last edited by alex mm; 4th November 2011 at 03:43 PM. |
#39 | |
I did checkout a few devices but these ones showed a superior performance
#40 |
| Wanted: DIY amplifier builder with experience. I need a 0.7 ohm stable amplifier | Audiophilenoob | Swap Meet | 34 | 16th May 2005 11:58 PM |
| Questions about how to decrease the PASS A-40 amplifier into a class AB amplifier. | novtango | Pass Labs | 2 | 21st October 2002 01:50 AM |
