Old 19th November 2011, 04:38 PM   #121
OnAudio is offline OnAudio  United States
Originally Posted by drowranger View Post
I have check the supplier the smallest casing is 26mm x 13mm it takes up the space of the whole input filter circuit.capacitor is metallised polypropylene is there any other way for this?
p.s. can i use metallised polyester or uncoated MKTpolyester capacitor and rating is 63volts?
regards,
joel
Hi Joel,
C8 Could be 4.7uF 16V NP . C6 100 uF 6.3V NP (you can get rid of the diode) unless there are any objections
kind regards
Old 19th November 2011, 04:45 PM   #122
pin configuration of bc 556 is cbe while mpsa92 is ebc.im planning to use 2n5401 and compatible to the board i have design.is this fine also?
Hi Joel,
Your progress and work is looking soo beautiful . You can use the 2N5401, however what you are creating looks promising that is why I even suggest using KSA992 if you can lay your hands on it
kind regards
Old 19th November 2011, 04:49 PM   #123
Originally Posted by OnAudio View Post
Hi Joel,
kind regards
This suggestion is for Q4, Q3 on your schematic
Old 19th November 2011, 05:16 PM   #124
Hi Joel,
Some suggested voltages
C1 200V
C2 100V
C3 100V
C4 100V
C5 6.3V
C6 6.3V
C7 35V
C8 16V
C10 63V
C11 63V
kind regards
Old 19th November 2011, 05:19 PM   #125
50V or 63V or 100V polyester or terephthalate or mylar. any of these will be far better than any electrolytic. All will be smaller than MKP, all will be cheaper than MKP.
You could go down to 2u2F or 3u3F.
2u2F gives up 2octaves of sub-bass. Might be worth trying that. You like the result.
Old 20th November 2011, 09:49 AM   #126
Default c6 to 100uf
I retain the diode just in case it will be needed.I found 4.7uf metallised polypropylene rated 250 volts for c8 this is the lowest voltage rating.Also change the layout.check again if this is final.
Old 21st November 2011, 03:03 AM   #127
Hi Joel,
Checked the schematic, looks OK.
Cheers
Old 21st November 2011, 04:35 AM   #128
Default using ksa992 and bc556b
Hi Joel,
kind regards
I change pcb layout for ksa992 and for bc556b.does bc556b superior than 2n5401.it looks like ksa992 is hard to find but will try to get it.
regards,
joel
p.s. now I can start for the pcb.
Old 21st November 2011, 11:22 AM   #129
Joel, very PCB designs are really nice.
Can I suggest you add pins to allow mounting this style of
multiturn trimpots too for more flexibility?
Old 21st November 2011, 11:32 AM   #130
That pic shows 3 inline pins.
Add a 4th hole/pad for the offset pin version.
This can be important when one wants the trim rotation direction to achieve the expected effect.
Wanted: DIY amplifier builder with experience. I need a 0.7 ohm stable amplifier Audiophilenoob Swap Meet 34 16th May 2005 11:58 PM
Questions about how to decrease the PASS A-40 amplifier into a class AB amplifier. novtango Pass Labs 2 21st October 2002 01:50 AM
Copyright ©1999-2013 diyAudio
