SYMEF amplifier
SYMEF amplifier
Old 17th November 2011, 04:10 PM   #111
OnAudio is offline OnAudio
OnAudio's Avatar
Default tracking diodes
Hi Joel,
Just to point out the output devices your using have tracking diodes, will you take advantage of them ?
kind regards
Old 17th November 2011, 05:58 PM   #112
OnAudio's Avatar
Originally Posted by OnAudio View Post
Use ceramic for high frequency feedback.
Use mica instead
Old 18th November 2011, 04:00 AM   #113
Samuel Jayaraj is offline Samuel Jayaraj  India
Nico, you drove your point home, jokingly!!
Sam
Old 18th November 2011, 07:08 AM   #114
OnAudio's Avatar
Default Type 3
Another representation
Old 18th November 2011, 11:23 AM   #115
Adjust C8
C8<= C6 * R19 / [R20+R21] / sqrt(2)
Anywhere in the range of 4u7F to 47uF will maintain good low bass response.
regards Andrew T.
Old 18th November 2011, 07:15 PM   #116
OnAudio's Avatar
Originally Posted by AndrewT View Post
Adjust C8
Hi AndrewT,
Here we go.
kind regards,
Old 19th November 2011, 05:29 AM   #117
drowranger is offline drowranger
Default check again
Hi Joel,
kind regards
the transistor you used not available and change it to 2stc5200 and 2sta1943 is this two ok?sorry for using the wrong output transistor.I already change c8,c6,r8 and zobel network.plus I include a diode in parallel with c6.is this correct?
regards,
joel
p.s. if no correction will be made I will try to buy pcb this week and will use toner transfer method.my printer is laser and produce solid black good for transferring.
Old 19th November 2011, 05:39 AM   #118
Default bc556
Hi AndrewT,
Here we go.
kind regards,
pin configuration of bc 556 is cbe while mpsa92 is ebc.im planning to use 2n5401 and compatible to the board i have design.is this fine also?
Old 19th November 2011, 11:23 AM   #119
Drow,
replace back to back C8 with a single plastic film 4u7F.
You lose one octave of sub audio low bass frequency response in exchange for the higher quality film over electrolytic caps.
regards Andrew T.
Old 19th November 2011, 11:43 AM   #120
Default 4.7uf
Drow,
I have check the supplier the smallest casing is 26mm x 13mm it takes up the space of the whole input filter circuit.capacitor is metallised polypropylene is there any other way for this?
p.s. can i use metallised polyester or uncoated MKTpolyester capacitor and rating is 63volts?
regards,
joel
SYMEF amplifierHide this!Advertise here!
Wanted: DIY amplifier builder with experience. I need a 0.7 ohm stable amplifier Audiophilenoob Swap Meet 34 17th May 2005 12:58 AM
Questions about how to decrease the PASS A-40 amplifier into a class AB amplifier. novtango Pass Labs 2 21st October 2002 02:50 AM
Copyright ©1999-2017 diyAudio
