After unboxing, removing their tops, and blowing some stink off, I got them warming quickly and actually played music! Here they are holding the amppads to the floor.
![]() Removed a bottom cover and was please to see much room around the output-stage PS caps, so I filled a little of it on two amps with pairs of BlackGate VK-series 2200/35 bypass caps. (Original caps are ELNA for Audio 22000/50s.) ![]() Will concentrate, initially, on the inputs, replacing the RCAs with Furutechs, adding 50K TDK pots*, and, to the lower-frequency amps, adding SoniCap Platinum hi-pass filter caps for the Vandersteen 5As' bottom ends**. Will post schematic soon. * Will lift the original 56K load resistor too. The amps have WAY too much--as in almost 30dB--Voltage gain, so the pots will allow me to get my preamp gain control where I want it, reduce system noise slightly, and tweak the level of the high frequencies easily. ** The VS Quatros, 5s, and 7s require a preceding, inline, or built-in-the-amp high-pass filter since the speaker has none in its x-overs. Last edited by jeffreybehr; 13th October 2011 at 12:11 AM. |
#2 |
Nice set-up Jeffrey, what is the black box in the center?
Kind regards Nico |
#3 |
And since the originals are 50V caps, did you check that the actual voltage on these is LESS THAN the 35V rating of the black gates????
#4 |
Nico, the black box in the center is a Vandersteen VCC-1 centerchannel-dialog speaker*. I've improved that, too, and haven't finished the cosmetics; that's why the black cloth is drooping.
Ilimzn, yes indeed I did. Voltage on schematic is 31; actual at my house is about 32. BTW the amp has a completely separate (starting with PT secondaries) supply for the frontend--51Volts. I will NOT be putting 50V caps in that. :-) Have found another spot where output-stage PS bypass caps sort of fall in and have added a couple more BGs per amp, this time 100/50 K-series. ![]() * Mine is a combination multichannel-music/home-theater system. The 8-feet-wide (NOT diagonal) screen is suspended on chains, and it's hung up, out of the way for these pics. The screen fills all but about 3" per side of the space between the V-steen 5As. Last edited by jeffreybehr; 13th October 2011 at 07:47 PM. |
#5 |
Nice setup.
I can't help thinking that keeping small children away from it would present a challenge, though. A friend of mine had his precious Linn Asaka cartridge ruined when his 2-year old son decided to investigate it. |
#6 |
Jeff, is retired - small kids are in the distant past. Nobody will leave kit on the floor if there was any possibility of children arriving unless in a cage.
Kind regards Nico |
#7 |
The Phily =>
Looks like Sponge Bob has killed another thread. |
#8 |
#9 |
Finished installing the two pairs of bypass caps in all amps. Received the new IC cable, custom assembled by Sonic Craft from Neotec NEI-3001 cable and Xhadow RCAs. Had 2 jacks installed at the load ends to drive 2 amps without jumpers or splitters.
![]() Have separated the amp ends of my single/double-biwire speakercable. ![]() This too was assembled by Sonic Craft, of Tefon-insulated UPOCC copper or silver, with 2 pairs of 18g. copper for the bass/MR and one pair copper and one pair 23g. silver for the MR/treble. The entire system sounds quite good even with lots of parts still breaking-in. |
#10 |
Strange things on those circuit diagrams, P-channel MOSFET 2SJ115 were connectet up side down and drawn as N channel.
| Look what I just bought--FOUR Marantz MA-24s. | jeffreybehr | Solid State | 1 | 2nd October 2011 06:05 PM |
| Crown MA-12000i / MA-5000i / MA-9000i | jack2040 | Solid State | 4 | 8th March 2011 01:21 PM |
| Marantz MA-700...Popping sounds? | Three Legs | Solid State | 6 | 8th March 2009 08:53 PM |
| marantz esotec ma-5 | meanman1964 | Solid State | 1 | 28th January 2009 06:08 PM |
| Marantz MA 500 or MA 700 schematic | krishu | Solid State | 0 | 15th March 2004 01:59 PM |
| Page generated in 0.11572 seconds (77.22% PHP - 22.78% MySQL) with 11 queries |
