Amp design for subwoofer and wideband duty
Old 30th September 2012, 12:49 PM   #111
Bensen is offline Bensen  Belgium
Bensen's Avatar
Thanks for the tip Patrick!
Any idea where I could buy these?
Old 30th September 2012, 01:10 PM   #112
meanman1964 is offline meanman1964  Belgium
meanman1964's Avatar
Maybe in car shop?Will take a look myself.
Old 14th October 2012, 08:51 PM   #113
Bensen's Avatar
Default Humming problem is solved!
I've put a 10R resistor between the audio ground (input and feedback) and power ground. With the input of the amp shorted, I can't hear a thing when keeping my ear against the tweeters.
Old 14th October 2012, 09:04 PM   #114
Bensen's Avatar
Default new design
During solving all issues discussed above and searching for solutions, I designed in parallel a new amp.
- better VAS ==> more dominant 2nd ant 3th harmonic during FFT analysis
- MKP input capacitor instead of MKT
- 33R - 470F buffer between rails and LTP/VAS section
- BJT drivers instead of FET's ==> big improvement in sound! ==> much more depth in music
- better input bjt's (1775/872 instead of 3381/1349)
See the attachment of the current design states. I put in a jumper to select High Open Loop Bandwith.
Old 14th October 2012, 09:31 PM   #115
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Originally Posted by Bensen View Post
I've asked one of the operators to change the thread title, sofar I haven't received an answer.
Changed it. Better use the report post triangle symbol, the one with the exclamation mark inside it for such requests also, so it goes in the reports queue that every mod sees, avoid PMs, they don't expect forum related requests there for sure.
Old 7th November 2012, 12:35 PM   #116
Bensen's Avatar
Default Upgrade + listening impression
A lot happened the last weeks.
- first I've said that changing the drivers from FET to BJT's improved the sound (more depth in the music)
- but after more listening, I liked the FET's as drivers more ==> a lot more detail/contrast in the music
==> disconnecting the middle point of the driver outputs with the ouput of the amp changed a lot.
I still have the PMA700V amp to compare with. At this point I for sure like my amp more than the PMA700V, my amp has more details in the hight's and better base response.
Have a look at the attachement, this is where I'm working towards. At this point the VAS degeneration is stil 560Ohm and LTP source resistors are 2K2. All the rest is identical.
Old 7th November 2012, 01:38 PM   #117
R.I.P.
open loop bandwidth seems unusually low @ ~+50dB
Are you measuring that correctly?
regards Andrew T.
Old 7th November 2012, 01:49 PM   #118
Bensen's Avatar
I checked it again, and yes, according to my knowledge teh 50dB is correct.
I use -V(a)/V(b) as parameter for AC-analysis.
It was actually one of my intentions to use a rather low open loop gain, as mentioned many times by NP, to much gain kills the live in the sound.
Old 3rd December 2012, 02:03 PM   #119
Bensen's Avatar
Default Stability tests on final version
I made a proto PCB from the final circuit below, in order to make some decent stabiltity tests.
personaly, I think this version sounds terrific. But besides sounding good, it has to be stable. I don't have much experience yet in square wave testing. Therefore I've attached pictures of the scope readings. The filename of the picture is: peak-peak voltage / Freq / 8R / C-load. The last two pictures are done wihth 4Vpp instead of10. If I increased the ouput voltage higher then 4Vpp with this load, there was massive ringing on the square wave.
Can anyone tell me whether i'ts good enough for home use?
Greetz
Old 4th December 2012, 02:04 PM   #120
Bensen's Avatar
Bump
Amp design for subwoofer and wideband dutyHide this!Advertise here!
Subwoofer Amp Design Suggestions SpikedCola Chip Amps 45 28th February 2011 01:31 AM
Offline SMPS duty cycle, core & bridge JohnT_diy Power Supplies 10 16th May 2008 10:22 PM
Advice on a 15"+ sealed subwoofer design gwgjr31 Subwoofers 25 27th April 2006 04:18 PM
I need help with my 30" subwoofer design jhung1983 Subwoofers 11 13th December 2005 12:48 AM
Just a little note : When you wideband amp oscillates at 200KHz and you dont know why sonnya Solid State 6 1st August 2003 06:08 PM
