Amp design for subwoofer and wideband duty
Old 6th August 2012, 07:32 PM   #101
Bensen is offline Bensen  Belgium
Bensen's Avatar
Smile Evertything finished except front and back
Amp is running perfect
-bias is lightly decreasing when temperature is goiing. (drops very little: from 180mA/15C to 175mA/40C)
-Protectionboard with the TA7317 is doiing his job properly.
-DC-servo is keeping output offset well below 2mv.
-Static DC control is funcioning perfect: this makes sure that DC-offset is already very low (+-10mv) when the output relay kicks in.
Must admit that I maybe hat to put small heatsinks on the HFA25PB60 rectifier diodes.
The topside will be made out of 6mm glass.
Front and back panel is something else, I'm looking for nice wood, which I want to varnish with a lot of layers to make it very, very smoot.
Old 6th August 2012, 07:34 PM   #102
Bensen's Avatar
Topview
Old 21st August 2012, 05:10 PM   #103
Bensen's Avatar
Default Upgrade or downgrade soundwise??
I've clearly made a mistake by using resistive loading on the VAS to increase openloop bandwith. Some members pointed me this out. Douglas Self and Bob Cordell are telling the same in their literature.
Instead of resistive loading I would like to use local feedback arround the VAS stage.
Please have a look at the PDF document and tell me this is the right way to go??
Thanks in advance
Old 27th August 2012, 07:26 PM   #104
Bensen's Avatar
Unhappy Upgrade results + oscillation
The change from above is an upgrade! The sound hase more detail! The hights sounds much better.
From the start on I heard some buzzing throught the speakers. First I thought it had to do with the messy wiring in the begin. But even now I hearing buzzing throught the speakers.
I did a bit invesigation with the scope:
==> I'm having +-10Mhz oscillation with 50mV amplitude! It looks as if the 10Mhz is running on top of a triangle like signal with a frequency of +-2Mhz.
What have I tried:
1) grounding the heatsinks => NOK
2) played with the zobel capacitor ==> 10R +10N/100N/1 ==> NOK
3) played with the OPS BIAS ==> Nothing changes
4) disconnected 1 amplifer in total (no ground loops) ==> Nothing changes
Can someone give me a tip?
See the pictures below.
File Type: pdf Final PCB layout - tracks + components.pdf (103.3 KB, 86 views)
Old 28th August 2012, 06:41 AM   #105
R.I.P.
c3, 4, 6, 7, 8 & 9 are all compensation as are r8 & 9.
Try increasing Miller comp around the VAS. That is the simplest and the results may give a clue to where you aim next.
Why did you choose 10n for the output Zobel?
How is it terminated? Does it have a long loop back into the output stage? If the loop is too long the inductance may be creating an impedance that prevents the Zobel doing it's HF job.
regards Andrew T.
Old 28th August 2012, 07:22 PM   #106
Bensen's Avatar
Thanks Andrew,
I will play arround a bit with the Miller comp the next days.
Concerning the zobel network. Both speaker output, zobel connection and feedback to IPS is only max 10mm from each other on the PCB. The 10n zobel cap is choosen without stability testing what so ever, I use 10n because it is a common value used for the zobel.
In general I've learned more things from this amp than I expected, and that's good.
Old 29th August 2012, 08:11 AM   #107
R.I.P.
100nF is more generally adopted for a Zobel, whether with or without the following R//L.
The bigger cap allows the amp output to see the damping resistor load from lower frequencies.
regards Andrew T.
Old 4th September 2012, 08:04 PM   #108
Bensen's Avatar
Luckily I swapped my matched output pairs with a testing pair. Because with testing other freq comp caps I managed to kill a pair of 2SK1530/2SJ201.
I increased the Miller comp from 33pf to 68pf, at the output of the drivers I measured +- the same oscillation. Also with connecting a speaker at the output of the drivers I heard exactly the same as with the 33pf miller comp.
I increasedthe gate stoppers from the drivers 2sk2013/2sj313 from 100R to 470R ==> no change.
I have no idea what is causing the hum/oscillation.
I think I'm gonna swap the driver FET to BJT's, jus to see what will happen.
Old 29th September 2012, 07:49 PM   #109
Bensen's Avatar
Question Amp is still humming
After some trial and error testing, I still haven't found what is is causing the humming through the speakers.
The hum is a sinus signal with a frequency of +-160Hz, measured on a scope.
Whe I keep my ear close to the transformer (amplimo 625VA), the transformer is making the same noise/hum as the speakers?
Any suggestion
Old 30th September 2012, 07:36 AM   #110
meanman1964 is offline meanman1964  Belgium
meanman1964's Avatar
Try something like this the man whom has done this had the same problem
Amp design for subwoofer and wideband dutyHide this!Advertise here!
Subwoofer Amp Design Suggestions SpikedCola Chip Amps 45 28th February 2011 01:31 AM
Offline SMPS duty cycle, core & bridge JohnT_diy Power Supplies 10 16th May 2008 10:22 PM
Advice on a 15"+ sealed subwoofer design gwgjr31 Subwoofers 25 27th April 2006 04:18 PM
I need help with my 30" subwoofer design jhung1983 Subwoofers 11 13th December 2005 12:48 AM
Just a little note : When you wideband amp oscillates at 200KHz and you dont know why sonnya Solid State 6 1st August 2003 06:08 PM
