I wish I knew more to be able to say: it's OK, or it's not OK.
I'm more inclined to: it's not OK and to chase up cb's zobel tweak.
I'm no expert,
Do you have output inductor ?
With 1uF capacitor, I would expect ringing to dominate,
but if amplifier is stable you won't loose 'nyquist' stability and amp won't fall into full oscillation.
I'm eager to read input from experienced members.
agreeand to chase up cb's zobel tweak.
Project finished
The amp is finished!!!
For pictures, see:
http://www.diyaudio.com/forums/solid-state/96192-post-your-solid-state-pics-here-284.html
For more data see the attachment.
And now: on to the next amplifier .....
For pictures, see:
