diyAudio Moderator Emeritus
Hi, this amp has a sensitivity of 150 mV for full power output which is way too much for nowadays sources. With the volume potentiometer at 8 o clock it is darn loud already. I wish to temper the sensitivity to around 300 mV or even 1 V.
My guess is that lowering feedback resistor R361 to 33k is enough. But what to do with R382 and C357 ?
It's only audio Last edited by jean-paul; 7th October 2011 at 07:48 PM. |
#2 |
Why not just put an attenuator on the input of the amp?
Changing the feedback will have multiple effects. It may make the amplifier oscillate.
Frank |
#3 |
You could try increasing C357 a little too, but HF stability is hard to predict as it depends to some extent on parasitic components which don't appear in the circuit diagram. You could find you have made a power oscillator! An attenuator at the input would be simpler.
#4 |
It has a volume potentiometer but if I barely touch it it is very loud. Gain is very high which made me think to change the feedback circuit. I also thought of possible oscillation but my knowledge in this area is lacking to say the least. It occurred to me that the resistors are very high in value too for a power amp feedback circuit. Long ago I was taught that the impedances at both inputs of a differential pair should be equal but I forgot the reason
Putting an attenuator before the volume potentiometer to have the signal later on amplified a lot again seems counterproductive IMO but I guess it is the safest approach.
It's only audio Last edited by jean-paul; 7th October 2011 at 08:20 PM. |
#5 |
With rail voltage around 40V it seems to be non-ES series SONY amp. It may seem a little strange you have problems with over-sensitivity. I have a bunch of SONY in my possession currently (630 esD, 650esD, F470, F519R), and even with SACD player with 2Vpp output the volume is rather "normal"( up to 11 - 12 with no problems, except the wife :-) ). I presume the "problem" you have is in both channels? ;-)
I would not be afraid to lower the value of R361 a little bit, the amps usually are more stable with deeper feedback. |
#6 |
At present one LTP base sees 51k, the other sees 100k in parallel with 100.62k. Near enough the same.
Adding 10dB to the feedback, as you propose, is quite likely to cause oscillation. Maybe not all the time, but with certain signals and certain loads. |
#7 | |
Yes, it is with both channels. It is not a problem but a feature It is a semi ES amp as it has ES parts (well there is ES written on the power transformer) and relay controlled inputs but is was not part of the ES series, I will let you guess which one it is.
It's only audio Last edited by jean-paul; 7th October 2011 at 09:06 PM. |
#8 |
Of course, you are right. the LTP bases both see nearly the same value. That is with R382 and with DC but what exactly is the purpose of this resistor ? Obviously a DC path but for what ? I checked some other Sony amps of that time and they have similar schematics ( with higher rail voltages) and the same feedback networks with R361 (51k), C356 and R357 (620 Ohm) but no R382 installed.
It's only audio Last edited by jean-paul; 7th October 2011 at 09:23 PM. |
#9 | |
alternative to lower the gain of the amp will obviously benefit the amp for the best if done properly
SERVICE ΙΑΠΩΝΙΚΩΝ ΜΗΧΑΝΗΜΑΤΩΝ ΗΧΟΥ www.eastelectronics.gr |
#10 |
"Kill dynamics"? Do you have access to a special source of music which has never been near any resistors?
"Drown the source"? Only if you use the wrong values. |
| Looking for Feedback on this No Feedback Amp. | MJL21193 | Solid State | 82 | 6th July 2009 02:53 AM |
| SOHA Amp & PSU Layout, need feedback | trip-pcs | Tubes / Valves | 5 | 22nd August 2007 04:48 PM |
| Old Sony SE OPT's /w 600r tap... cathode feedback maybe? | aletheian | Tubes / Valves | 23 | 24th September 2006 03:50 PM |
| 'Local Feedback and Nonlinearity of Multistage Feedback Amplifiers' | mikeks | Solid State | 62 | 20th July 2005 08:03 AM |
| Page generated in 0.10524 seconds (87.84% PHP - 12.16% MySQL) with 11 queries |
