This a FYI to anyone new who might have a heart attack when popping the hood on their GFP-565. I just upgrade my power from a Yamaha R9 (it died) to a Adcom GFA-555 and 565 preamp to drive my Polk SDA 2As. When I opened the top on the 565 I noticed mucho brown substance coming from the bottoms of ALL the capacitors (see pics). At 1st glance I cursed because the preamp was in mint condition. Upon 2nd glance (after I had wiped my tears) I found it to be some sort of adhesive used at the bottom of each and every capacitor. Is this normally the way the caps are put down?
O and by the way the Yamaha R9....good riddance! Probably a good receiver but these Polks have been taking it easy for the last 25 years with me. Now they be getting spanked. I know I am at the bottom end of the audiophile bucket equipment wise but I sure don't feel like it! It sounds great......just ask the neighbors....... |
#2 |
I believe that the 565s are notorious for leaking and/or exploding caps.
-Charlie |
#3 |
Hey Charlie. I don't believe these are leaking at all. There are eleven capacitors in the preamp in four different locations. All the spaces where the substance is located have a common area of displaying themselves as shown in the pics. I poked them a little with the end of small screwdriver and it is semi-hard and much like an adhesive.
#4 |
Hello, that does appear to be an adhesive for holding the caps down to the PCB. It's been used fairly regularly since the 70's. I recall demolishing clock radios, walkie-talkies, etc. in the 80's that were 70's era, and they had the same sort of stuff on them. No leakage to speak of.
I haven't heard of the Adcom preamps having issues with leakage from the Electrolytic Caps, but some of the power amps did have issues from what I have read. Especially some of the GFA-555's of certain eras. I suspect that Anatech will have better details about this. ![]() Peace, Dave |
#5 | |
Good to hear from you, Kevin |
#6 |
Hmmm, tube setup? That's one thought. Or you could go look at Pass Diy, and really get bitten by Papa's infectious designs! From what I have read, the Balanced Zen Linestage is similar to the Adcom GFP-750 preamp that Nelson Pass designed for Adcom. And that was Adcom's flagship for more than a few years.
Peace, Dave Last edited by dave_gerecke; 7th October 2011 at 04:07 AM. Reason: typo |
#7 | |
I am so new to this game is ain't even funny so I have a lot to learn. My learning curve goes up up and away! I know nothing about amps except what I have learned since buying mine 2 weeks ago. Up until then I owned a receiver that output 100 Watts per channel into 8 ohms. It stopped there. So now I have this monster amp designed by Nelson and I am giddy with it. I will need to learn some things about some things before I take on a DIY Pass project. However I am seriously contemplating asking for a solder station for Bday! Have a good multi-meter and a knowledge of electronics but only enough to be dangerous. I think it looks like a great hobby. (Encrypting file so wife cannot read) Kevin |
#8 |
Hey Kevin, I'm not saying no to the Tubes, as I have so many different things around here I can't criticize anyone. I just figure that perhaps a PassDIY preamp would go well with your GFA-555. Especially when it's similar to a preamp that Papa Pass designed for Adcom.
I also recommended trying something from one of Papa's DIY designs, as he provides some pretty good information about the designs. Check out Pass Diy and start reading! Peace, Dave P.S. Build one of the Pass design preamps. Then get into the tubes also!
#9 |
Hi Kevin,
Please, do you have any tech docs about the R9 that died? I need a Service manual or at least a schematic to try to revive mine. No results searching the net. Thank you. Cheers, Antonio Falcao |
| Adcom GFP-565 Service Manual | KT | Solid State | 4 | 9th November 2011 06:13 AM |
| Looking for schematic for Adcom GFP-555 (not GFP-555II) | dougzilla | Solid State | 8 | 18th August 2011 05:51 PM |
| Adcom GFP-565 IC Part Numbers??? | Zero Cool | Analog Line Level | 6 | 15th January 2010 06:00 PM |
| Adcom GFP-565 OpAmp question | KT | Solid State | 2 | 10th July 2007 08:02 AM |
| adcom gfp 565 op-amp upgrades question? | crippledchicken | Parts | 1 | 22nd November 2006 05:33 PM |
