From Your knowledge/experience are there any cons in using LEDs for current sources and cascode stages ?
Thank You |
#2 |
Rod Elliott uses a green led in his famous PROJECT 3A.
http://sound.westhost.com/project3a.htm Ciao Lorenzo |
#3 | |
Electrons are yellow and more is better!
But it's not bad when the LED is there and tweaked in, but it hopeless if you want repeatability and precision.
/Per-Anders (my first name) or P-A as my friends call me |
#4 | ||
Account Disabled
Per is right with regard to variable tolerances from one LED to another.....However one significant advantage is that LED's provide very effective temp. compensation for your current source....compared to ordinary diode-biasing. |
#5 |
The temperature compensation isn't so important in most cases as long as the current source has sufficient feedback and the environment is "home". IF it's important it's better to use a monolithic pair instead, cheap but hard to solder.
BC847BS at the picture --- can't reach my homepage right now. But I have a picture at the bottom of the page http://home.swipnet.se/~w-50719/hifi/layout_qsxm2.html http://home.swipnet.se/~w-50719/hifi/qsxm2_layout.html I'm not sure of the file name.
#7 | |
A LED provides very low noise, too. I can't see any reason why using a TL431 instead of a LED. Use a brand like a TLLR3360. |
#8 |
I can, the dynamic resistance is under 1 ohms in a 431 and the temperature stability is better and the initial tolerance better, but it isn't the same type of component.
#9 |
Without coupling the ref pin to emitter of a (NPN) the temperature stability is worse. Simply couling the TL431 with the ref to a PNP is not possible. Noise is higher. Initial tolerance is not better (refering to the datasheet). 1% of a LED is the same as the resistor used to set the current of the CCS. So I can't really see any reson why using the shunt reg, although it'll make the job.
I'd strongly recommend the LED. |
#10 |
I'm talking more from the perspective of series production. You can't really on purpose design in a part which is so special. Parts with no second source is a nightmare.
| Cascode Buffers | acoustixman | Solid State | 43 | 26th August 2008 04:04 PM |
| Cascode Output Stages | pietjers | Solid State | 118 | 20th April 2008 06:56 PM |
| Page generated in 0.12133 seconds (76.71% PHP - 23.29% MySQL) with 10 queries |
