diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Solid State (http://www.diyaudio.com/forums/solid-state/)
-   -   2SK135 2SJ50 Replacement (http://www.diyaudio.com/forums/solid-state/19789-2sk135-2sj50-replacement.html)
Marvellous 4th September 2003 11:10 AM
2 Attachment(s)
I just Received a Trace Elliot PA1200
Boards from a friend who has ripped them out
of his amp after blowing it:bigeyes:
This Amp is a verry impressive Pa Amp and
I would like to Revive it!:nod:
the only problem is It uses 2SK135 & 2SJ50
Outputs and I can't find these anywhere:bawling:
Are there equivalents that I can Use?:scratch:
Here are Attached Pics
UrSv 4th September 2003 11:21 AM
http://home.swipnet.se/~w-50719/forsale/index.html
matth 4th September 2003 11:48 AM
The UK based company Profusion sells there own brand of lateral mosfets (Exicon) and has equivalents for the 2SK135 and 2SJ50:
http://www.exicon.com
I have deal with Profusion in the past for small numbers and I can not recommend them highly enough.
StuartH 4th September 2003 11:49 AM
Hi Marvellous
I asked a similar question some time ago. The Exicon parts seem to be about the closest youll get.
http://www.profusionplc.com/hitachi.htm
No idea where to get these in SA. I have tried without success.
One could always replace them with something significantly better, as the 2SK135 and 2SJ50 are pretty old. I dont remember if IR makes a IRFP240/9240 equivalent in a metal can package.
Any suggestions out there???
Cheers, Stuart
diyman 4th September 2003 11:55 AM
Mosfets
RS components still stock the 2SK135 and 2SJ50 although these are not made by Hitachi anymore. Hope this helps.
StuartH 4th September 2003 12:03 PM
Hi diyman
Thanks. Didnt realise RS would have them. I dont tend to use RS as here in SA they are HMMMMM expensive.
Stuart
peranders 4th September 2003 12:50 PM
I'll be happy to sell a couple of those Hitachi's. My are original and in it's original box. Very Hitachi in other words. :nod:
Marvellous 5th September 2003 07:48 AM
Have just Email you Preanders! Price?
Some one has just told me that I can use
2SJ162 2SK1058 as replacement?:scratch:
is this true?
as these are not TO3:scratch:
peranders 5th September 2003 08:06 AM
is this true?
Those are not TO3 but fits if it's not too tight. The electrical properties are similar but not exact. The threshold voltage is higher for instance. In many places you can use them but in some designs you have to adjust a little, especially the bias arrangements.
Marvellous 5th September 2003 10:43 AM
I don't understand what you mean?:scratch:
do you mean they will work but will not give same power?
or they will work but wont get same quality?
or they might not work at all?
peranders got your email Thax!
Resources saved on this page: MySQL 18.75%
