I've uploaded a small article about an old but somewhat forgotten technique of distortion reduction applied to a single-ended FET amplifiers (could be used with valves too).
http://www.ant-audio.co.uk/Theory/Ap...e_Feedback.pdf Perhaps Nelson will make another ZEN Cheers Alex |
#2 |
Looks like the upper FET is run in
Shunt Regulated Push Pull, SRPP This is used with Tubeamplifiers. The second harmonic is very suppressed giving lower overall THD
lineup |
#3 | |
Cheers Alex |
#4 |
The effect is so marginal it looks practically worthless.
Are there actual circuits where it would be of some value?
#5 |
#6 |
#7 | |
voltage gain factor of the FET >> gain with indirect feedback transconductance of the FET times resistance of the two feedback resistors in series >> gain with indirect feedback Is that correct? By the way, I like the circuit. It is a variant of indirect feedback I hadn't seen before. |
#8 | ||
Cheers Alex Last edited by x-pro; 3rd October 2011 at 07:49 PM. |
#9 |
Maybe I have missed something, but to me the first circuit looks like it has a drain load consisting of an FET wired as a CCS, in parallel with a 1k6 resistor. The second circuit has a slightly modified CCS in parallel with a 50K resistor. I would expect the first circuit to give high distortion. Nothing to do with indirect negative feedback, just a matter of changing the drain load for a triode-like device. Elvee gets much better results for the first circuit because he uses a much higher resistor value.
The 'explanation' also mentions identical FETs (OK in simulation, but where do you buy them?) and FETs whose drain current is independent of drain-source voltage (same question!). The second circuit might work OK, but not for the claimed reasons. |
#10 | |
Regarding the second point - for JFETs of the same type the transfer function for the same drain current would be identical enough for a good distortion compensation even when the devices are not matched perfectly (or at all) . The only problem would be a DC offset which would have to be corrected in either circuit by changing the bias voltage on V5 and V2 respectively. And the third point -- even 2SK170 have enough voltage gain for this circuit to be useful and if required you can cascode two different JFETs in a usual manner - for example, as on the picture attached. Cheers Alex Last edited by x-pro; 3rd October 2011 at 08:34 PM. |
| Indirect method of sound creation | jzagaja | Planars & Exotics | 5 | 4th December 2008 06:47 PM |
| 'Local Feedback and Nonlinearity of Multistage Feedback Amplifiers' | mikeks | Solid State | 62 | 20th July 2005 08:03 AM |
| Non-feedback parametric linearisation in FETs | x-pro | Solid State | 41 | 9th January 2005 06:56 PM |
| Page generated in 0.12813 seconds (81.52% PHP - 18.48% MySQL) with 11 queries |
