finerly found schematics for this sony ta-f444es,can it be tweeked in any way,i.e caps transistors ,transformer etc etc.IMG.jpg
IMG_0001.jpg IMG_0002.jpg IMG_0003.jpg IMG_0004.jpg IMG_0005.jpg IMG_0006.jpg IMG_0007.jpg IMG_0008.jpg |
#2 |
Too blurry to make out... what are the opamps in the next to last pic ? Looks to be a servo wrapped around two opamps in the signal path.
------------------------------------------------------- A simulation free zone. Design it, build it, test it. |
#3 | |
TL082P AND NE5532P hope that helps.?? P011011_13.27.jpg thats about as good as i can get it mooley. Last edited by paul.42; 1st October 2011 at 12:30 PM. |
#4 |
this is the best i can get the schematic pics,see what you think.
thanks for looking P011011_13.27.jpg P011011_13.33.jpg P011011_13.36.jpg P011011_13.36_[01].jpg P011011_13.36_[02].jpg P011011_13.37.jpg P011011_13.37_[01].jpg P011011_13.38.jpg P011011_13.39.jpg Last edited by paul.42; 1st October 2011 at 12:56 PM. |
#5 |
If it's older than 20 years, renew all the electrolytic capacitors. Look for electrolytics in the signal path and see if you can substitute Wima MKS2 series polyesters in their place.
Opamps - nothing wrong with the NE5532's, leave them be. You'd likely have to mess around improving local decoupling if you were to change them, anyway. Overall, a well built amp by Sony. If I had one criticism, it's the tone control in the power amp's feedback path - i've never liked this method, but it was commonly done on amps of this era. |
#6 |
Thanks for the rescan... it's a bit of a quirky design in parts.
Good advice from Jaycee on the caps etc but I'm going to suggest you look at those opamps. It's an odd arrangement... the overall phase of the two opamps gives a 180 degree phase reversal so that is obviously for political correctness in maintaining non inverting of phase for the amp as a whole. The DC servo is needed as the last opamp feeds the "attenuator" control (is that the balance control ?) and so any DC at all would result noisy operation as the pot is turned. The TL082 is perfect for use as a DC servo but the 5532 I think could be bettered here maybe with some other small tweaks... If you are interested I'll give it some thought because it's quite an unusual arrangement and, while many opamps would work straight off it would be good to optimise it.
#7 | |
#8 |
I'll have a think on the opamp stage...
Pots... it's either a case of finding new that are physically the same, going multiturn and drilling the board so they fit properly (nothing worse than ill fitting parts with bits of wire
#9 |
This opamp stage isn't quite so obvious in its operation as you might think... that's why I wanted to think it through. More than that I actually breadboarded it to investigate.
Easy bit first... the TL082. As I mentioned a FET opamp like this is perfect for a DC servo but two thoughts came to mind. I'm puzzled (well down to cost I suppose) why the better specified TL072 isn't used. It has a lower noise... does that matter... well in theory it does feed directly into the first audio opamp stage. Absolutely nothing lost in swapping it if you wish although in practice it may be a half of a quarter of nothing as far as total noise is concerned. The 330 ohm on the servo non inverting input to ground is a curiosity. It serves no purpose to the operation of the circuit as the FET opamp inputs have currents measured in the femto amp range. Maybe the machine that populated the PCB "didn't do wire links" The NE5532... You have choices. The LM4562 is the successor to the 5532 (one I haven't used) and has a good reputation. The OPA2604 is one I have used and would definitely try as it does seem to have a "unique" sound quality (musical in the best sense of the word). The other to try is the OPA2134. So maybe fit sockets for the 5532 replacement and listen for yourself.
#10 |
thanks for taking time to look into the opamps
| sony ta-f444es mk2 schematics | paul.42 | Swap Meet | 4 | 1st September 2011 04:45 PM |
| wanted transformer for sony ta-f444es mk2 | paul.42 | Swap Meet | 5 | 5th August 2011 12:56 PM |
| Sony TA-F35 help | endeo | Solid State | 5 | 13th May 2011 08:18 AM |
| Sony TA-N1 and TA-NR1, how do they sound? | lumanauw | Solid State | 0 | 28th November 2006 01:51 AM |
| FS: Sony "Esprit" TA-E901 and TA-N901 pre and power amp | MJR | Swap Meet | 1 | 6th December 2003 07:55 PM |
| Page generated in 0.12038 seconds (83.67% PHP - 16.33% MySQL) with 11 queries |
