hi
greetings looking for simple diy short circuit protection schematic which can be incoporated into amplifiers any help will be helpful short circuit i mean if speaker wires touch each other ACCIDENTALLY warm regards andrew lebon |
#2 |
You really need a circuit integrated into the amplifier itself.
Do a search of DIYAUDIO and you find loads. Alternatively use a fast blow fuse.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software. |
#3 |
Fuses suck. They blow right after the amplifier fails. How about don't fool with the wires while it's running? After I blew up enough amps I decided not to mess with the wiring while it's playing and haven't had an issue in over 30 years.
G² |
#4 | |
I tripped over a speaker wire and shorted it out and the fuse blew before the amp. I guess its getting the fuse value right, not so small it blows for no reason and not so big it doesnt blow at all.
#5 |
Transistor is the fastest fuse...
Amplifier must have all protections included in it's own circuit. It is almost impostble to do it ,,outboard,, But of course fuse can work ..... at least sometimes and it depends what is the amp....build for. If you need it to power some pub....sound system than is more than ok. In case of hi-end, no thanks....it is not just a wite in glass tube but is unlinear element in pwr rails.....or in the signal chain.....it depends. But one thing is sure. In terms of safety very recomended to prevent fire.....or at leat high damage... Regards, Taj |
#6 |
U have to watch the voltage across the high wattage resistors connected in series with output transistors.
Gajanan Phadte |
| short circuit protection | roofingboom | Solid State | 109 | 1st May 2012 02:28 PM |
| Overload / Short Circuit Protection, Yet Again... | Buckeye | Solid State | 44 | 16th February 2011 03:52 PM |
| Short-circuit protection | black | Solid State | 2 | 30th October 2010 08:09 PM |
| Short circuit protection | MiiB | Solid State | 0 | 16th May 2006 06:48 AM |
| Short circuit protection | JBL | Solid State | 20 | 5th August 2002 07:27 AM |
| Page generated in 0.08818 seconds (76.55% PHP - 23.45% MySQL) with 10 queries |
