I have been thinking that a linear adjustable regulator, like the LM317, allows you to vary the output voltage by varying the adjustment pin current.
So in theory, if you manage to vary this current depending of the voltage amplitude of a musical signal, you should be able to modulate the output voltage of the regulator in concordance. In the same way that when you trim a pot, the output voltage varies, but in function of a musical signal. It may sound a little funny, but with a decent slew response rate maybe the sound can be decent. Has anybody ever tried something like that? What are your ideas for varying the input current of the adj. pin byt following a signal? Regards, Regi
diyAudio, doing it as big as you can, JUST BECAUSE WE CAN! |
#2 |
just another
#3 |
Well, now I feel like comin' late to the party
Thanks!
#4 |
and there have been a few designs from years ago posted on the Forum.
regards Andrew T. |
#5 |
It becomes more logical if you consider the 317 as a high-gain medium power transistor with a negative Vbe of 1.25V
NPN of course; the 337 would be the PNP equivalent. jan didden
/Another new issue: Linear Audio Volume 3! |
#6 |
Have a look here (non-exhaustive):
Class A buffer using LM317 3 terminal reg's Quasi-complementary Hexfet monstrosity. 4-part Harmony, a 9 watt class A amp using a voltage regulator IC. New kind of compound emitter follower?? or - another weird circuit ;-) Just for fun: The Regulator-Chip amplifier And now, the Regulator-Chip JLH Amp. The Voltage-Regulator-Chip Amp family welcomes a new member: Class A Chip Amp: and now, the complementary version What happens when you cross a Tringlotron with a Regulator-Chip Amplifier? SE class A regulator-chip-amp madness
#7 |
A former colleague of mine actually came up with an amplifier circuirt using LM317 and LM337 while working for synth maker Sequential circuits. This was back in the the late 70's/early 80's. The curcuit escapes me right now, but no doubt one of you busy folks out there will rough something out.
| Help with input stage driver for EL84 output stage | AudioGeek | Tubes / Valves | 2 | 20th March 2010 01:38 AM |
| 3C24 in a SE output stage - output transformer impedance recommendation !!! | aldovan | Tubes / Valves | 15 | 6th September 2008 10:18 AM |
| Output stage biasing, with the driver stage | andrew_whitham | Tubes / Valves | 0 | 19th May 2007 11:14 AM |
| Adding secondary of output transformer into cathodes of output stage ? Eico ST-70 | freddymac406 | Tubes / Valves | 3 | 21st April 2007 06:15 PM |
| input output diferential in LM317 | Pablo | Analogue Source | 4 | 15th June 2004 04:26 AM |
| Page generated in 0.09867 seconds (74.67% PHP - 25.33% MySQL) with 10 queries |
