Old 27th September 2011, 10:48 AM   #1
Toltec is offline Toltec  United Kingdom
Default Leach Capacitor Upgrade
Greetings All,
I'm a newby currently building a Leach 4.5. I've made and drilled the PCBs and have a box of components begging me to get to work. All components are pretty much standard, as per Prof Leach's BOM. It struck me that it may be worth upgrading some of the capacitors with polyprop ones before getting my soldering iron out.
Given my lack of experience, I'd really appreciate your opinions as to which ones are worth changing... I found the link below from another post for reference.
http://img166.imageshack.us/img166/8651/ampleachfq5.gif
Your thoughts are much appreciated!
Gary
Old 27th September 2011, 01:30 PM   #2
OK, just read the following article:
Capacitor Characteristics
It seems if it aint broke then don't fix it. :-)
Old 27th September 2011, 03:48 PM   #3
Ron AKA is offline Ron AKA  Canada
He is using some 100 uF electrolytics on the power rails, with a 100 nF bypass. You could increase the size of the electrolytics and use ones with a very low ESR. The bypasses could be increased to a 0.47 uF metalized polypropylene. Don't see any input or output caps that you need to be concerned about.
Old 27th September 2011, 04:30 PM   #4
AndrewT is online now AndrewT  Scotland
Caps that pass audio onto the next stage will likely benefit from better types, eg PP (either foil or metalised) instead of MKS or MKT.
The exception is the NFB DC blocker, it generally needs to be so large that only electrolytics can do the job there. But be very wary of using an electrolytic that is too low in value.
The rail decoupling should (some would say "must") be very close to the devices that can suddenly change in current, eg. output devices.
regards Andrew T.
Old 27th September 2011, 11:17 PM   #5
This National Semiconductor article may give you some ideas on what can be done at the power supply stage.
Old 28th September 2011, 07:28 AM   #6
Thanks for the info guys!
capacitor upgrade on my tube phono stage colls65 Tubes / Valves 11 18th December 2009 12:32 AM
X-Over capacitor upgrade UV101 Multi-Way 7 1st May 2009 12:43 PM
Capacitor upgrade in Paragon 12A xronx Tubes / Valves 4 8th July 2007 05:37 PM
Capacitor upgrade calvinhpk Parts 6 2nd November 2005 06:57 AM
Capacitor Upgrade (Plate Amp) BAM Solid State 4 25th July 2002 03:45 AM
Page generated in 0.07817 seconds (82.23% PHP - 17.77% MySQL) with 10 queries
