Old 26th September 2011, 09:20 PM   #1
Default tranformer noise
May I dip a power transformer in orange shellac to glue everything in place and ge rid of the hum noise.
Is dielectric constant of orange shellac close to the usual varnish used in power ransformer industry. ( secondhand transformer from a HP PROPRINTER )
In my case they are standard steel laminated standard E & I core
Old 27th September 2011, 08:47 AM   #2
tiefbassuebertr's Avatar
check out this:
http://www.dalitech.com/Resources/Me...ansformers.pdf
and this:
dc filter
Old 27th September 2011, 09:56 AM   #3
Originally Posted by tiefbassuebertr View Post
check out this:
and this:
dc filter
This thread seems to focus only on DC at the primary transformer winding. But it must be considered that also DC drawn from transformer's secondary results in singing toroids. One-way rectification will result in direct current and that will result in hum, even if it is only used for low power auxiliary supply.
Guthorst
Old 27th September 2011, 01:49 PM   #4
I will check for dc component in mains , I may also test with an isolation transformer and get rid of any DC component and any ground loops.
These transformer are use to power Leach Amplifieir, if there is an unbalance in secondary winding and DC through secondary it must be a very low value.
Old 27th September 2011, 01:58 PM   #5
AndrewT is online now AndrewT  Scotland
Using a bridge rectifier virtually ensures equal loading on the two halves of the output windings.
You don't need to concern your self with induced DC due to unequal loadings until you deliberately draw unmatched current in the to & fro directions.
regards Andrew T.
Old 27th September 2011, 02:00 PM   #6
Mooly's Avatar
This explains it quite well...
Mains DC and Transformers
As to dipping in varnish... that doesn't always have the desired effect although that said I have done that many times when I was a bench tech working with cheap equipment.
A simulation free zone. Design it, build it, test it.
Old 27th September 2011, 02:52 PM   #7
Bonsai is offline Bonsai  Taiwan
The first thing you need to do is decide if the noise is because there is DC on the mains, or, whether your problem is infact just loose windings and/or loose laminations. in the case of the latter, dipping the transformer in varnish of lacquer will certainly help. if its DC on the mains, you need an entirely different approach. See Rod Elliot's site for a good technique to remove DC from the mains.
bonsai
http://www.hifisonix.com/
Old 27th September 2011, 05:11 PM   #8
digits's Avatar
Often a simple filter like a 220nf x2 capacitor in series with a 10W, 1 ohm resistor from live to neutral, placed before the transformer will clear the hum up alot.
Old 4th October 2011, 02:55 AM   #9
I made a test tonight with an isolation transformer, since you cannot get DC from a transformer there was no DC in primary.
But the transformer noise did not change at all.
Old 4th October 2011, 04:49 AM   #10
U have to shield the transformer i.e. enclose the transformer in mu metal or copper. Even iron will do as most commercial audio does the same.
Gajanan Phadte
Mains tranformer noise tidalweapon Tubes / Valves 33 4th June 2011 03:40 PM
Gainclone tranformer rmcelroy Chip Amps 5 18th August 2010 04:07 PM
Step down tranformer jkeny Everything Else 2 18th October 2005 12:14 AM
Tranformer question CPX Parts 3 7th February 2005 07:44 PM
Can someone explain this tranformer? dvdwmth Chip Amps 5 9th September 2004 08:03 AM
Page generated in 0.10616 seconds (76.45% PHP - 23.55% MySQL) with 10 queries
