#71 | |
"The total harmonic distortion is not a measure of the degree of distastefulness to the listener and it is recommended that its use should be discontinued." D. Masa, 1938 |
#72 |
#73 |
L.C. Audio is looking for material used to The End mk.3.1 ....alternatively Millennium.
Is there still files and material for the two DC amplifiers, they try to return with a price estimate. |
#74 |
Anyone who knows replacement transistors for the discontinued Sanken 2SC2922 and 2SA1216?
2SC3722K smd seems to have data like 2SC2240 exept for the noise. 0,2dB/100uA for 2SC1455 and 0,5dB/100uA for 2SC2240 2SA1455 smd with data as 2SA970 ...exept for the noise. 2SA970/2SC2240 could be used as input pair in The End mk.3.1?? The End mk.3 PCB: https://picasaweb.google.com/vbkolse...81461722260994 The End mk.3 schematic: https://picasaweb.google.com/vbkolse...25839818957314 |
#75 | |
Not sure whether "2SA970/2SC2240 could be used as input pair in The End mk.3.1??" ....either? |
#76 |
#77 | |
I was looking for the ring-emitter types for output, because they are fast and linear. Secondly because the MT200 house indicates a good heat dissipation due to the large metal plate. |
| Page generated in 0.87781 seconds (100.00% PHP - 0% MySQL) with 10 queries |
