No - feedback amplifier - Page 6 - diyAudio
Old 24th January 2013, 12:36 PM   #51
Telstar is offline Telstar  Italy
Kim, thank you very much for all the work you are putting on this. SMD soldering isn't friendly to my eyes, so I would go for the through-hole "the end".
Go ahead and start the GB, 100 pcs will take a month or more to reach i think.
"The total harmonic distortion is not a measure of the degree of distastefulness to the listener and it is recommended that its use should be discontinued." D. Masa, 1938
Old 24th January 2013, 02:38 PM   #52
Telstar, you're welcome! If possible please spread the news....we might be able to convince L.C.Audio to produce the PCB's again.
Even that I work with optical lenses the small SMD components is not for me ....to use a forceps in order to solder a 2,5mm capacitor or a 2mm resistor....(may be less that 2mm) Hmmmm ...I like 1/4 w Beyslag's approx. 9mm lenght
Forgot to say:
Five guy's told me that Picasa Web are useless for reading ....this is not correct. Use the magnification button above the jpg. picture...when the magnification is ok , use the high-lighted window in the right bottom corner to navigate with
Old 24th January 2013, 05:30 PM   #53
Jpeg quality is nowhere as good as the original pdf you made, can you upload it somewhere?
Old 24th January 2013, 08:45 PM   #54
I have just tried at Flickr and PhotoDrop...same result. Let's try here ....there are permission of 976 kb in this forum.....you can get two pictures
Old 24th January 2013, 08:48 PM   #55
next
Old 24th January 2013, 09:04 PM   #56
Why you insist with pictures? The text is not searchable etc. your site doesn't allow to host a small file? I can guess 2MB tops, then put on a place like mediafire, just google free file hosting.
Old 24th January 2013, 09:05 PM   #57
Picture upload is very slow here.....
Telstar, I made the jpg.pic out of a pdf. file which original was a zip from scanned pictures. Consequently the resolution is a result derived from the earlier miserable scan.
That's all for today.
Rgds. Kim
Old 24th January 2013, 09:13 PM   #58
What do you mean with the text is not searchable. I think it's easy enough to read. And yes you are right ...if I had the possibilty to upload 2Mb on my payment free site I would have done just that.
Rgds
Old 24th January 2013, 09:14 PM   #59
I see. I'll try to OCR it with acrobat pro when I get it all.
Old 24th January 2013, 09:31 PM   #60
Gudmund is offline Gudmund  Iceland
Hello ...what is it, if not pictures from a scan, copy of text...picture copy?
Copyright 1999-2017 diyAudio
