Old 24th September 2011, 07:31 PM   #1
Cool Easiest/Economical way to build multichannel Class A/B amp? Suggestions Welcome
I'm planning an amplifier build for an outdoor sound setup for my father around the swimming pool, and porch/patio area.
I'm wanting to minimize labor on my part, I don't etch my own PCB, and I don't feel like making bunch of veroboard amps, because there's more effort /errors in soldering connections. Those boards are fine for amps I build myself, but not for a multichannel amp IMO. However, if an IC chip solution is easy, and I can use vero with that, it may be OK.
I was originally going to build a massive mono amp, for raw power and simplicity, but it was mentioned about having different volume controls for different sets of speakers, instead of them just being wired all together. Also mentioned he wants stereo regardless, so mono is out of the question now.
I believe it's better to make a multichannel amp instead of in-wall speaker volume controls, but I could be wrong, that's why I'm asking some suggestions/opinions.
I've considered just getting 3 stereo Rod Elliott P3A boards, but I'm open to options on easiest way to build and other ideas too. I desire at least 3 pairs of speakers (6 channels)
You can call me Mad Professor, building crazy experiments in my Electronics Workshop
Old 24th September 2011, 08:03 PM   #2
How much power do you need? What speakers are you driving?
Old 24th September 2011, 09:49 PM   #3
Ok the requirements for power and speakers are not real strict, other than the fact they are plastic cone & rubber surround to use outside in the weather, and they have to be loud enough to hear clearly about 10-30 feet away. They will actually be located 5 feet on each side of the swimming pool, and and 30 feet away, but on the porch, so they don't have to be super loud, but loud enough to hear everything with noise from water and people. I figured I'll build some small sealed speaker boxes to keep critters out the speaker boxes, and get some cheap 5 or 6.5 inch plastic/rubber speakers from Parts Express to put in them, and some plastic tweeters. They don't need a lot of bass, just need to be loud enough and handle high wattage so they don't die if turned up sometimes.
My guess would be 40-100W RMS per speaker. My goal was 200-400W total for main speakers. It doesn't matter, just as long as they are loud enough.
For bass, I'll use a Subwoofer PA box with two cheap car audio 15's in it, so they play proper in the big box with another amp, so I'm not real concerned with that, because that's the easy part. I'll have at least 200W for that.
Old 24th September 2011, 11:14 PM   #4
jaycee is offline jaycee  United Kingdom
I'd probably say use LM3886 chip amps simply because they are cheap, and have inbuilt protection. The P3A would work, but if something causes a short on the output, they'll die. Look for something that has VI limiting.
Old 24th September 2011, 11:25 PM   #5
2pcs QUAD 405 125W+125W power amplifier kit | eBay
About $15 for a stereo pair. I've made these things work just fine.
But why not just buy a bunch of secondhand 1990s commodity hi fi Japanese amplifiers from eBay for about $10 each complete? You're not looking for perfection after all, and that would be 'plug'n'play.
Or these class D things?
http://www.ebay.co.uk/itm/NEWEST-TA2...item3cbb914026
Or a '400W' 5.1 surround amp for about $70?
http://www.ebay.co.uk/itm/5-1-HOME-C...item519b111896
Old 26th September 2011, 02:47 AM   #6
That Quad 405 kit looks nice. Also the other ideas.
The ball is rolling, thanks so far for the ideas, as it may seem to be more economical than I thought.........
Help: Choosing an amp chip for a multichannel amp build the7trumpets Class D 5 9th July 2010 05:50 AM
first class d build suggestions. brookbh Class D 7 26th April 2010 06:48 AM
Easiest to build class-A? Doug Kim Solid State 17 26th September 2008 10:16 PM
Simplest, Cheapest, easiest amp to build? Gsteg Solid State 14 4th March 2004 10:30 AM
Page generated in 0.10771 seconds (76.89% PHP - 23.11% MySQL) with 10 queries
