I recently repaired this amplifier. It was shutting down and blowing fuses. I replaced all output transistors, fuses and a lot of resistors which were recommend changes by Manufacturer. Could you please hep me to determine why R2-24 is still causing a problem? I powered amplifier without speakers or input. R2-24 burned in 1 second. I turned of amp immediately.
R2-14 is definitely open. It was a new resistor yesterday. Thanks for your expertise. The traces are very tiny so I will look for excessive solder and study the schematic to the best of my ability. I would sure like to know what caused R2-14 to burn as well.
What are the possibilities?
I have for lack of confidence in my testing skills, replaced all resistors and transistors again. I would rather do things right then my current component swapping method. I am about to power up amplifier. Glass is half empty and I am expecting a little mushroom cloud. Board is mounted, transistors are mounted to heatsinks. I have powered the amp without fuses and all is well. Can I substitute a lower transformer voltage to look for anomalies or should I hit switch and watch for sparks?
I don't have a variac. First attapt, I blew fuses. Last time, fuses didn't blow but a resitor in series with output trans burned. Transformer puts 56-0-56 in to each channel. What if I were to feed 25-0-25 and look for heat. I am just guessing here. I like the lower fuse idea. Is current dependent on how hard it is being driven? If so, I could put in some 2a and idle it. The resitor that burned was to the supply of the output transistor.
- Amplifier burning resistor.
