diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Solid State (http://www.diyaudio.com/forums/solid-state/)
-   -   Why 3 dB? (http://www.diyaudio.com/forums/solid-state/196946-3-db.html)
gmphadte 20th September 2011 07:24 AM
Why 3 dB?
Why is the bandwidth specified at 3dB points?
Many a times, I tried to find answer for this, but non r convincing.
Gajanan Phadte
Lazy Cat 20th September 2011 07:28 AM
Look at here. ;)
diypwj 20th September 2011 09:14 AM
It is the half power point if I remember well
DF96 20th September 2011 09:42 AM
That wikipedia entry contains a glaring mistake. It talks about voltage dropping by 1.5dB. Wrong! A voltage drop by 3dB (0.707) results in a power drop by 3db (0.5). This often confuses newbies (and some others!!).
digits 20th September 2011 09:46 AM
And it is only part of why it is chosen as the cutoff frequency as opposed to any randomly selected fraction. 3db is the smallest increase/decrease in volume which can normally be perceived by the ear. So everything within a 3db band, sound equaly loud (provided you had totaly flat hearing :P).
gmphadte 20th September 2011 09:58 AM
Originally Posted by digits (http://www.diyaudio.com/forums/solid-state/196946-3-db-post2717380.html#post2717380)
This is the answer I gave in a very early interview, but unfortunately all the other things like half peak power and all the other explanations are known to many, which I think r not correct. If they r correct, why should it be not be specified at any other arbitrary power level.
Gajanan Phadte
DF96 20th September 2011 10:10 AM
It is correct to say that -3dB is half power. The issue then becomes "why choose half power"? It is a nice round number, and in many circumstances is the minimum which will be easily noticeable. It also emerges from the theory of single-pole (or first-order) filters: -3dB is the point where the angular frequency is equal to 1/CR, and the phase is 45 degrees. For most amplifiers the frequency limits are defined primarily by first-order filters.
Copyright ©1999-2017 diyAudio
