Why 3 dB?
Why 3 dB?
Old 20th September 2011, 08:24 AM   #1
gmphadte is offline gmphadte  India
Default Why 3 dB?
Why is the bandwidth specified at 3dB points?
Many a times, I tried to find answer for this, but non r convincing.
Gajanan Phadte
Old 20th September 2011, 08:28 AM   #2
Lazy Cat is online now Lazy Cat  Slovenia
Lazy Cat's Avatar
Look at here.
Old 20th September 2011, 10:14 AM   #3
diypwj is offline diypwj  Italy
It is the half power point if I remember well
Old 20th September 2011, 10:42 AM   #4
DF96 is offline DF96  England
That wikipedia entry contains a glaring mistake. It talks about voltage dropping by 1.5dB. Wrong! A voltage drop by 3dB (0.707) results in a power drop by 3db (0.5). This often confuses newbies (and some others!!).
Old 20th September 2011, 10:46 AM   #5
digits is offline digits
digits's Avatar
And it is only part of why it is chosen as the cutoff frequency as opposed to any randomly selected fraction. 3db is the smallest increase/decrease in volume which can normally be perceived by the ear. So everything within a 3db band, sound equaly loud (provided you had totaly flat hearing :P).
Old 20th September 2011, 10:58 AM   #6
This is the answer I gave in a very early interview, but unfortunately all the other things like half peak power and all the other explanations are known to many, which I think r not correct. If they r correct, why should it be not be specified at any other arbitrary power level.
Gajanan Phadte
Old 20th September 2011, 11:10 AM   #7
It is correct to say that -3dB is half power. The issue then becomes "why choose half power"? It is a nice round number, and in many circumstances is the minimum which will be easily noticeable. It also emerges from the theory of single-pole (or first-order) filters: -3dB is the point where the angular frequency is equal to 1/CR, and the phase is 45 degrees. For most amplifiers the frequency limits are defined primarily by first-order filters.
Why 3 dB?Hide this!Advertise here!
Audax PR170M0 100 dB or just *94 dB?? rick57 Multi-Way 44 22nd December 2013 01:50 AM
116 db peak db how loud is that 8cube Multi-Way 21 8th November 2007 07:45 AM
About DB Meter MatrixElect Multi-Way 3 12th January 2005 04:54 PM
89 db is it enough ? MlinarS Tubes / Valves 18 12th January 2005 08:09 AM
Coverting dB/2.83w to dB/1w moving_electron Multi-Way 27 9th March 2004 03:47 PM
Copyright ©1999-2017 diyAudio
