"The Wire AMP" Class A/AB Power Amplifier based on the LME49830 with Lateral Mosfets
Update
BuildMeSomething 2x DPS-600-45/55V (Reg LME)
lolo 6+4 x DPS-600-45/55V (Reg LME)
Emphrygian 2x DPS-600-55/65V (Reg LME)??
igor0203 2x DPS-600-55/65V (Reg LME)
QRikard 2x DPS-600-55/65V (Reg LME)
qusp 2x DPS-600-55/65V (Reg LME)
NicMac 2x DPS-600-55/65V (Reg LME)
Arthur 4x DPS-600-55/65V (Reg LME)
hochopeper 2 x DPS-600-55/65V (Reg LME)
KiWik 2x DPS-600-55/65 (Reg LME)??
55/65V- ended
45/55V- ended
payments:
Lolo; QRikard; NicMac;Qusp;BuildMeSomething;hochopeper;arthur;
need to confirm: Emphrygian;KiWik;
Update
55/65V- ended
45/55V- ended
payments:
Lolo; QRikard; NicMac;Qusp;BuildMeSomething;hochopeper;arthur;igor0203;
lol, how considerate of you :p
AP2, assuming the DPS-500 measures well, will the folks buying the DPS-500 also receive a discount?
Neb001, just i see that you followed well this GB and not have smps, i can offer one dps-500/D at price on shop but for Wire Amp. this mean 65V for lme unregulated or other voltage you need. performances is ..very good at 110Vac,dps-500 have two feedback same fast response.
perhaps someone who was not in the first list could give their up?. John there isnt going to be another GB mate unless people put together another large group to justify the custom production, the model available on the shop will not have the higher voltage for the LME. not happy with this situation, I dont think its fair at all.
AP2 I didnt think you were doing another lot with this format supply?
like you said, makes custom lme this product. we can give it a try, maybe you can get to 30pcs. Today started the production of the basic version, which will be derived / DA and AB class with + /-15V aux. We can now create the new GB, given that we have time. or include the DPS-500 / D for 110Vac and see what happens.
The window was open for such a short time and I have been at work unable to check the site hourly.
What happened to the first list?
May be the supply can be modiffied post production or will one DSP 600 supply 2 LME 49830s using the second for the output stage ? the only problem being if one rail is up before the other? John
You are right John, this dps-600 in GB are ready with fixed voltage. is not possible change voltage post-production..this is problem.
eg. from production arrive dps-600 assembled but without power-unit. after with power unit, we chose voltage output. even power-unit follow same way.
Is good that one dps-600 supply lme and power dc of amp.
Guys,
I have 4 DPS-600 regulated on hold for the end of the month, 45/55v.
If Roberto is keen to offer me the same price on the next batch, I am happy to put these back up for people who are missing out, I don't need them straight away, but I will need exactly the same voltage AND regulated. I am also happy to pay a deposit to Roberto to avoid any confusion, and to confirm the last 4 supplies I ordered.
Let me know.
Cheers
Update
johnwallis 1x DPS-600-55/65 (Reg LME)
55/65V- ended
45/55V- ended
payments:
igor0203;johnwallis;
This is the current situation.
Thank you lolo, you do not need to send a deposit for 4 SMPS, yes, I can confirm the price if you want to make available for others, this is a nice gesture on your part.:)
Update
55/65V- ended
45/55V- ended
payments:
igor0203;johnwallis;Emphrygian;
