"The Wire AMP" Class A/AB Power Amplifier based on the LME49830 with Lateral Mosfets
Old 18th June 2014, 11:06 AM   #2331
rhythmsandy is offline rhythmsandy
have you tested with the regulators for the LME is there any sonic difference perceived?
Old 18th June 2014, 11:18 AM   #2332
The C77 is 10uf/10v is this a metallized film capacitor or and electrolytic? if so electrolytic then using a non polar film cap will improve the sound quality?
Old 4th July 2014, 03:03 AM   #2333
nine76chris is offline nine76chris  United States
My boards came in. Same circuit (minus the DNPs) with option for a 2nd pair.
Old 4th July 2014, 08:58 AM   #2334
palstanturhin is offline palstanturhin  Finland
palstanturhin's Avatar
Hi!
I like how the mute circuitry is taken to the chips power side. I actually like that very much!
The chips GND pin (nr 3) is the return for the mute pin (nr 2). If I see correctly, that is now taken to the opposite direction? I would like these two tracks to closely follow each other. But that is hardly any problem on your PCB if the mute input is kept clean from injecting interference to the board (ground plane)...
Supply bypass caps could be a bit closer to the chips power pins. You use Fischers SK145 as heatsink? There is room "inside" the heatsink for the negative rail cap.
You use also SMD on the board. These supply caps could be MLCCs. With SMD you can get ridiculously close to the chips power pins.
...Just a couple of ideas if you plan to make a v.2 of your board some day...
Anyways, excellent work! Congratulations! You could sell some of those on the sites Swap meet forum...
Will be waiting for your test results and most important of all; how does it sound!!!
Old 4th July 2014, 01:04 PM   #2335
Originally Posted by palstanturhin View Post
Hi!
Thank you. This is the first board I've done so I could use all the advice for the next version. There are a few vias connecting the gnd planes around lme pin2. The heatsink is here....
heatsink
I'm surprised how cheap the boards were to have made. 11 boards $100usd shipped.
Old 16th August 2014, 02:05 PM   #2336
hochopeper is offline hochopeper  Australia
Well this post isn't quite 'The Wire' related it feels a lot more 'on topic' than some of the recent posts ....
I am a born procrastinator. So I decided to keep my LME49830 amps and DPS600 PSUs on a shelf until I had my speakers ready. I've now got my speakers ready to power up and time to open the box with LME49830 amps and finish off my 4ch monoblock in one chassis build (2 channels of LME49830 'the wire' and 2 channels of the wire lpuhp). These will power my 2 way active speakers via 4pole speakon outputs.
All going well up to here.
I have tested one amp on a bench PSU and ramped its voltage up slowly, all went well there too.
Then I snapped my M3 tap in the heatsink as I was making mounting holes for the second amp ... now I need to wait till a week day to get my hands on a new one locally.
So with the mechanical items at a road block for a few days, I thought lets test these DPS600 PSUs so I could maybe finish the other working and mounted amplifier.
The best I could find quickly for testing the PSU before connecting the amps was 470R 10W resistors and connected these between the each rails to gnd.
First of the DPS600 powered up quickly as expected.
Second DPS600 never finishes its power up, the LED beside the output flickers and the output fluctuates between 29 and 31V although watching the multimeter during power up does seem to indicate that maybe it gets to something higher then drops down again. The LED that indicates power up complete stays infuriatingly unlit.
This happens when using either the standby switch or just hard power on from the power point switch.
I thought I'd ask if anyone else with DPS600 for these amps had any thoughts to offer before I email audio-power support? I think Audio Power will be on summer vacation at the moment so rushing to email them tonight does not help.
I remember buildmesomething had some issues after turning it on with a high bias setting, I'll go and read through his experience shortly and see if any of the symptoms with blinking LED are matching what was discussed then.
Chris
Old 16th August 2014, 02:11 PM   #2337
Lazy Cat is offline Lazy Cat  Slovenia
Lazy Cat's Avatar
Read a bit the First One thread and see the troubles we had with their SMPS.
Old 18th August 2014, 02:11 PM   #2338
Hi Lazy Cat,
I had a look through your thread, did you repair the module that you were testing or just test it with regulation broken? Sounded like something damaged in transit, like similar situation for mine also. Having seen the performance from the measurements that Owen took in this thread I'd like to repair mine, will get in touch with AP when they're back for help identifying the portion of the circuit needing attention.
Chris
Old 19th August 2014, 12:44 PM   #2339
I ended up sending a note to audio power while I had the info fresh in mind. A support guy had popped into the office during their vacation and was able to answer my query and confirm my suspicion of the likely failed part which I've now ordered and will see how repair goes next week. Hopefully repairs go smoothly and I avoid posting it back to Italy!
Chris
Old 2nd September 2014, 01:33 AM   #2340
Replaced the likely culprit on the DPS600 ... still not working ... further discussion with AP support was good (responded to 3 emails within 30mins each time!) ... unfortunately it is now time to send this one back to AP
"The Wire AMP" Class A/AB Power Amplifier based on the LME49830 with Lateral MosfetsHide this!Advertise here!
Marriage from "ZEN" - and ordinary class AB topology about HCA - why not realized ?? tiefbassuebertr Pass Labs 2 4th January 2014 04:52 PM
X-Amp (LME49830 + Exicon Lateral Mosfets) danfo098 Chip Amps 28 14th October 2013 04:05 AM
"CA-10", new Single Ended Power amp Device based on Aleph or ZEN ? tiefbassuebertr Pass Labs 1 29th September 2010 06:55 PM
Compound Lateral FET for higher power Class AB amp. Mooly Solid State 17 22nd August 2010 02:13 PM
Improvments to "Tube Headphone Amplifier/Preamp with Relay-Based Input and Power Swi" kipman725 Headphone Systems 4 17th August 2009 06:12 PM
Copyright ©1999-2017 diyAudio
