"The Wire AMP" Class A/AB Power Amplifier based on the LME49830 with Lateral Mosfets - Page 230 - diyAudio
Old 13th March 2014, 12:09 PM   #2291
IanAS is offline IanAS  England
Originally Posted by Stammheim View Post
360mA I'd like to know where they have to be measured... between both +-rails? Between +/- and GND?
If that's current through the output mosfets, then it's rail to rail. You take off one supply wire from the PSU to one side of the mosfets and either insert a meter set to current measurement, or insert a low value resistor of sufficient wattage, eg 1 Ohm or something, and measure the voltage drop across it and use Ohms law to calculate the current.
Old 13th March 2014, 02:16 PM   #2292
I just noticed I wrote some rubbish, as of cource I measure in series. So I just need the positive rail, for example, which I put the meter into it. Right?
Old 13th March 2014, 06:57 PM   #2293
palstanturhin's Avatar
Right?
Right...
Old 19th March 2014, 08:14 PM   #2294
Hi guys,
I hope, anybody can help me...
When powering on my amp it just made "klick" and the SMPS showed a short circuit.
As I understood from the schemata, the P-Mosfet has to be soldered to the -rail, so the left side of the PCB.
Right?
I hope I have not killed neither the mosfets nor the LME
Thanks,
Stammheim
Old 20th March 2014, 10:34 AM   #2295
Yes, the P channel is connected to the -ve rail.
Yes, the P channel is on the top left of the PCB, next to the -ve labeled terminal.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 25th March 2014, 02:22 PM   #2296
opc is offline opc  Canada
opc's Avatar
How is the bias pot set? It should be turned fully clockwise at startup for minimum current. This is opposite of what you would expect, but it's covered in the assembly manual.
If you had the pot fully CCW, then you would be pulling maximum bias current, which is way too high for the SMPS at startup.
Owen
Old 27th March 2014, 12:22 PM   #2297
Of course fully clockwise.
What I found out is that the LME49830 didn't work.
I seem to have got some defective parts, the LME49830, LME49990...
The other guys work fine till now...
Old 27th March 2014, 12:36 PM   #2298
opc's Avatar
Hi Stammheim,
Where did you source your parts from? That's very concerning if you're having issues with multiple parts.
The only other thing I can think of is that the parts were damaged by ESD. Is your workspace set up in a reasonable manner? Do you have an anti-static mat or wear a wrist strap?
Of all the parts I've soldered (and there have been thousands), I have only ever seen one IC failure, and it was an OPA1632 that had excessively high 3rd order harmonic distortion. I chalked it up to me being careless with ESD, and just replaced the part with one from the same rail, which was fine.
The fact that you've had 4 faulty parts now means something is definitely out of the ordinary, either with your parts supplier, or with the way you're assembling/soldering.
Owen
Old 27th March 2014, 05:42 PM   #2299
Hi Owen,
I got all my parts from Digi Mouser or Reichelt (a German distri). I guess I have killed the first reg by myself and by parallel connecting of both amps to one transformer the other one. The defective regs might have demaged the LME49990's. Soldering and the working place are alright. I soldered my most complex amps (SystemD_2k by Chocoholic, see d-amps) without errors.
The LME49830 was in fact a surprise for me, too. However, at the moment everything is fine, and maybe I'll also find an optimum solution for both LPUHP's, like I wrote in the LPUHP-thread
Old 15th April 2014, 10:23 PM   #2300
Hi and congratulations for the very nice layout
Is there any PCBs left from the 2nd batch ?
Marriage from "ZEN" - and ordinary class AB topology about HCA - why not realized ?? tiefbassuebertr Pass Labs 2 4th January 2014 04:52 PM
X-Amp (LME49830 + Exicon Lateral Mosfets) danfo098 Chip Amps 28 14th October 2013 04:05 AM
"CA-10", new Single Ended Power amp Device based on Aleph or ZEN ? tiefbassuebertr Pass Labs 1 29th September 2010 06:55 PM
Compound Lateral FET for higher power Class AB amp. Mooly Solid State 17 22nd August 2010 02:13 PM
Improvments to "Tube Headphone Amplifier/Preamp with Relay-Based Input and Power Swi" kipman725 Headphone Systems 4 17th August 2009 06:12 PM
Copyright 1999-2017 diyAudio
