Old 2nd February 2013, 04:44 PM   #2041
opc is offline opc  Canada
opc's Avatar
Originally Posted by miklos View Post
I purchased a kit from a member, but the SMD resistor values doesn't match the shcematic from the first page. Any reason for that?
You need to read the first post right to the bottom...
There's a link posted there to the updated schematic and assembly instructions:
"The Wire AMP" Class A/AB Power Amplifier based on the LME49830 with Lateral Mosfets
The attachments in the first post cannot be modified, which is why there is a big warning in bold letter with the updated post and attachments.
Owen
Old 4th February 2013, 04:53 PM   #2042
npdot is offline npdot  United States
Look at Post #742.
Enjoy,
Neel
Old 6th February 2013, 10:10 AM   #2043
miklos is offline miklos  Canada
Thanks very much to both of you.
miklos
Old 2nd March 2013, 11:48 PM   #2044
Default Fault finding...
Wow, this thread was way back down the list. Took ages to find...
For starters, not a huge up-date from me just more fault finding. Both dps-600's have been up & running after hurting them and one of the amps.
One amp appears to be running fine, however, it's reading 70 to 80 mV on the output with the dps-600. Need to check this with a lower V supply.
The broken & fixed [supposedly] amp was showing some high readings at the output and this [hopefully] has been traced to the P-channel FET. Please, is THIS the correct part?
The DPS-600's now won't start-up with a load =>50mA... Grounding issue perhaps???
|-O-|
Purchased a Raspberry Pi [arrived yesterday] and that got me iching over getting the amps up and running once more. Thoughts are to ditch the dps-600's and go for a lower +/- 20 to 25V supplies...
Paul
Listening with gusto...
Old 3rd March 2013, 12:31 AM   #2045
opc's Avatar
Hi Paul,
Send me a PM with your address and I can see if I can mail you a replacement fet. I have a few extras and it will save you buying it.
You problem does indeed sound like grounding issue, as that's the only thing I can think of that would cause a DC offset that high. The only other thing might be grossly mismatched rails on the LME, but even that shouldn't be an issue.
What version are you building? Did you follow the guide closely?
A few pictures might help as well.
Owen
Old 3rd March 2013, 12:30 PM   #2046
Thanks Owen, PM sent...
Amp setup, SE AC coupled build spec as per build guide.
Amp A - Setup A: Bias; minimum, single The Wire psu +/- 23 VDC rails. Measured 1.4mV offset at speaker output. Measured 2.5 to 3 Vdc spike on powering off at speaker output.
Amp A - Setup B: Bias; minimum & 360 mA, dps-600 +/- 55/45 VDC rails. Measured -0.8mV offset at speaker output. Measured 2.5 to 3 Vdc spike on powering off at speaker output.
Amp B - Faulty / blown P-channel fet. Replaced LME, mute components and a few smd caps.
DPS-600 - Initial power up using soft start switch, OK at 360 mA bias.
DPS-600 powering down to power up behaviour [on off on]: bias => 50mA
< 5 sec gap, power up failure.
=> 5 sec gap, power up successful.
Grounding - Uncased, both the remote soft-start switch [dps-600] and small wire on the signal input, cause slight variations on the measured offset as they are moved / touched.
Paul
Old 3rd March 2013, 12:43 PM   #2047
This sounds like DPS600 protection taking time to reset ...
Under Construction:Ian's i2s FIFO wiki
Old 3rd March 2013, 08:50 PM   #2048
back is offline back  Greece
owen if you have spare fets i could use two pairs.
Old 5th March 2013, 06:00 PM   #2049
I am in the process of matching fets for the next wire project. +/- 80/90 volt rails, 3 parallel pairs per channel. The fets I received were in 2 seperate plastic tubes, 10 in each tube. The 5th fet in one of the tubes that I thought were all N channel fets was a P channel. I didn't find this out till after hooking the fet up to the test jig that I made. No smoke and it appears to work ok when hooked up properly. All the fets so far are close to each other in parameters. I am matching at 150ma and 1 amp current. They are much closer than bjt's.
The first wire amp has been running pretty much every day. It's still running and sounding fantastic. Many thanks again Owen.
Old 5th March 2013, 11:13 PM   #2050
multisync i would like to buy 2 pairs of the spares if you want.i plan on two parallel pairs per channel and +/-70/80 volts rails. it would be nice if you share the test jig too.
X-Amp (LME49830 + Exicon Lateral Mosfets) danfo098 Chip Amps 27 31st December 2012 12:56 AM
Marriage from "ZEN" - and ordinary class AB topology about HCA - why not realized ?? tiefbassuebertr Pass Labs 1 18th January 2011 10:51 PM
"CA-10", new Single Ended Power amp Device based on Aleph or ZEN ? tiefbassuebertr Pass Labs 1 29th September 2010 06:55 PM
Compound Lateral FET for higher power Class AB amp. Mooly Solid State 17 22nd August 2010 02:13 PM
Improvments to "Tube Headphone Amplifier/Preamp with Relay-Based Input and Power Swi" kipman725 Headphone Systems 4 17th August 2009 06:12 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
