"The Wire AMP" Class A/AB Power Amplifier based on the LME49830 with Lateral Mosfets - Page 198 - diyAudio
Old 7th November 2012, 02:55 PM   #1971
rsavas is offline rsavas  Canada
Default Wire Amp Muting?
Hello folks,
Been following this thread, as i am working on my own version of this design. Thanks for the feedback, helps me figure out some design issues I have in my implementation.
So based on this Mute issue, I take it that you need to have a AC present & absent detector.
A simple transistor ckt to ground the mute pin quickly in the absence of an input AC voltage, sounds like what you are requiring. That and a mute delay at power up. This is why we prototype, test and then improve, all part of the design process, know one is at fault here, so strong words are not required.
I am undecided how I will do my speaker protection part of the design. Contemplating a full speaker protection ckt, AC line detect, o/p DC detect, over current detect, turn-on delay, relay for the speakers? I understand the reasons to have these features and why not. All part of the design process. If anyone has input for me please express it in the thread that I have created, rather than de-rail this thread
LME49830+LatFET, yet another for design review
AndrewT, not sure why you are saying that the zener "Z1", 12V is not needed. It has to be there to limit the input voltage to the LME49830 mute pin. Looking at the LM49830 spec, I can not determine the maximum V the mute pin can tolerate, they only say 120uA min to put the part into play mode. So I assume that Owen (OPC) just followed the guidelines from the data sheet and app note info.
Hi Owen, thanks for your design contribution, helps me alot in my efforts. If you are open to me asking you some questions about my design, I would appreciate it very much. We could do this off line. Who knows one day I might be able to buy you a beer or two/lunch/dinner, I realize that you are in Ottawa, so I am not that far from you or if you are in the GTA at some time in the future.
Rick
Old 7th November 2012, 03:07 PM   #1972
opc is offline opc  Canada
opc's Avatar
You don't need the zener if you calculate the resistor value properly:
IMUTE = (VMUTE VBE) / (1kΩ +RM) where VBE ≅ 0.7V
The problem lies in the fact that the calculated resistance only really works with one supply voltage (over a reasonable range) and needs to be adjusted as per the above formula for different supply voltage.
Using the zener simplifies this as you can use any rail voltage you want and the current into the mute pin is always the same.
If you were designing this into a product with a set rail voltage, it would be cheaper and easier to simply calculate the right resistance and omit the zener.
Owen
Old 7th November 2012, 03:38 PM   #1973
IanAS is offline IanAS  England
So...
Another resistor can be inserted between the capacitor and the mute pin. The relay joined to the mute pin. This way, when the relay earths the mute pin, the capacitor discharges slowly and doesn't weld the relay contacts.
During the period of earthing there will be some small current flowing through the resistors, via the relay, to earth.
Would that do it?
Same relay can also be operated remotely from, say, a pre-amp. (by interrupting the voltage to the relay)
Old 7th November 2012, 04:15 PM   #1974
Default LME49830 mute circuit
Ya, it would help if I looked at the LME49830 block diagram to see the 1K res in series with the diode to gnd. I am a real Homer Simpson at times :-)
I guess they could have spec'd the maximum current into the mute pin node, but I am sure is not to be over say ~100mA.
See why I am asking for help!!
Old 7th November 2012, 04:20 PM   #1975
opc's Avatar
National specifically states that exceeding 2mA into the mute pin could damage the IC, so that's your limit. If I were designing it, I would target about 900uA at nominal Vcc since that's in the middle of the specified allowable range. The last thing you want is the IC muting during a large transient that loads the supply rails, or getting destroyed under high line conditions.
See the appeal of the zener?
Owen
Old 7th November 2012, 04:24 PM   #1976
Yes sir, that just cost me one beer, do you have a preference? Gotta learn how to read, damn, right there in print on p12.
Thx Rick
Old 7th November 2012, 04:31 PM   #1977
qusp is offline qusp  Australia
qusp's Avatar
Thx Rick
I gather asking that sort of question of opc could get expensive...
Old 7th November 2012, 04:57 PM   #1978
That' s okay, I am having fun with it & I don't even know if he (Owen) indulges in such activities. Has not taken me up on my offer, so I do wonder. By the sounds of my stupid ?'s you'd think I was already toasted, it's only just noon here & I am at work today.
Old 7th November 2012, 05:00 PM   #1979
qusp's Avatar
oh he does, the commonality of good beer, good coffee and good audio was discussed earlier in the thread, or was that the LPUHP thread? hmmm one of the myriad wire threads anyway
Old 7th November 2012, 05:01 PM   #1980
opc's Avatar
I wish
I'll take one of these... definitely the nicest triple at the LCBO right now, if you can find one.
Product Information
Owen
Marriage from "ZEN" - and ordinary class AB topology about HCA - why not realized ?? tiefbassuebertr Pass Labs 2 4th January 2014 05:52 PM
X-Amp (LME49830 + Exicon Lateral Mosfets) danfo098 Chip Amps 28 14th October 2013 05:05 AM
"CA-10", new Single Ended Power amp Device based on Aleph or ZEN ? tiefbassuebertr Pass Labs 1 29th September 2010 07:55 PM
Compound Lateral FET for higher power Class AB amp. Mooly Solid State 17 22nd August 2010 03:13 PM
Improvments to "Tube Headphone Amplifier/Preamp with Relay-Based Input and Power Swi" kipman725 Headphone Systems 4 17th August 2009 07:12 PM
Copyright 1999-2017 diyAudio
