"The Wire AMP" Class A/AB Power Amplifier based on the LME49830 with Lateral Mosfets
Old 31st July 2012, 04:05 PM   #1891
NicMac is offline NicMac  Italy
NicMac's Avatar
Originally Posted by AP2 View Post
I see Silence...zZz..Zzz...work all on WA at sea? while i'm in lab..ahah!
or ...zZz..Zzz... waiting for SMPS
Old 1st August 2012, 04:56 AM   #1892
arthur is offline arthur
i am also waiting for the smps
Old 1st August 2012, 06:14 AM   #1893
igor0203 is offline igor0203  Slovenia
Too hot for soldering right now
Old 1st August 2012, 09:05 AM   #1894
AP2 is offline AP2  Italy
Banned
Hi, I hope Nicmac and Kiwi, confirm the receipt of the package.
Arthur: there are only your DPS-600, are stopped for lack of stupid caps 1206. Distrelec not send me (the rest of the 100 not available) so I'm looking to buy today from another supplier. I solve this today, Many apologies for this arthur.
Since I received some pm for DPS-500 (for new wire-amp), I will discuss (in DPS-600 threads), some aspects. they are ready because they have been assembled from services, so they need only the power unit and the final test. I mean, can be shipped in a couple of days. (I will not repeat the folly of the first GB, I worked on it for 5 weeks)
Old 1st August 2012, 12:43 PM   #1895
neb001 is offline neb001  United States
Has OPC posted measurements of the DPS-500? Wondering if I missed them or if people are just ordering them anyway
Old 1st August 2012, 12:50 PM   #1896
opc is offline opc  Canada
opc's Avatar
I was supposed to get a pair for testing, but I think it fell through.
I would still be interested, as I'm back to using linear supplies and would really like to build these into smaller finished chassis if possible.
AP2:
Can you send me an email about this? I've got a little bit of spare time where I could test these.
Owen
Old 1st August 2012, 01:54 PM   #1897
Banned
I was recently asked if I could send 2xdps-500 (voltage?) maybe you have not read the thread.
Considers that at full load (100Hz), drops by 3V
Old 5th August 2012, 07:54 PM   #1898
BuildMeSomething is offline BuildMeSomething  United Kingdom
Default LME Gain
@opc, or anyone who might know...
I've populated the pcb's using the guide and stock values from the BOM & will be using +/-55V/45V dps-600's... do we need to alter the Gain to reflect the +/- rails and source V's?
Only built headphone amps so far, so am unsure if Gain is used/adjusted in the same way on this as it would on a head-amp!?
Paul.
Listening with Gusto!
Old 5th August 2012, 08:58 PM   #1899
opc's Avatar
Hi Paul,
I would suggest leaving the gain as it is. Going lower may cause instability, and you would only really need to go higher if you had a source with very low output capabilities and you could not get the overall level to where you needed it with your finished system.
If this is your first power amp build, I would definitely start off with everything as standard as possible, and later evaluate if you really need to increase the gain.
The voltage used on the PSU doesn't really impact what gain setting you should use until you start getting into very high voltages. If you want to run +/- 100V rails to get some 500W into 8 ohms, then you would likely need more gain to allow you to swing more voltage on the output. In that case, if you only had about 1VRMS drive from your preamp, you might want to consider increasing the gain a little to get the desired output.
Owen
Old 6th August 2012, 09:19 AM   #1900
Thanks Owen, I'll leave that well alone then...
"The Wire AMP" Class A/AB Power Amplifier based on the LME49830 with Lateral MosfetsHide this!Advertise here!
Marriage from "ZEN" - and ordinary class AB topology about HCA - why not realized ?? tiefbassuebertr Pass Labs 2 4th January 2014 04:52 PM
X-Amp (LME49830 + Exicon Lateral Mosfets) danfo098 Chip Amps 28 14th October 2013 04:05 AM
"CA-10", new Single Ended Power amp Device based on Aleph or ZEN ? tiefbassuebertr Pass Labs 1 29th September 2010 06:55 PM
Compound Lateral FET for higher power Class AB amp. Mooly Solid State 17 22nd August 2010 02:13 PM
Improvments to "Tube Headphone Amplifier/Preamp with Relay-Based Input and Power Swi" kipman725 Headphone Systems 4 17th August 2009 06:12 PM
