"The Wire AMP" Class A/AB Power Amplifier based on the LME49830 with Lateral Mosfets - Page 178 - diyAudio
Old 8th July 2012, 06:03 PM   #1771
qusp is offline qusp  Australia
qusp's Avatar
great news mate, thanks for the update!
Old 8th July 2012, 07:15 PM   #1772
That is good news, great to hear everything is going well
I'll make a decision on case work once everything is in hand, but now need speakers for this... a pair of XTZ 99.25 will work well for the space I have.
Listening with Gusto!
Old 9th July 2012, 02:34 AM   #1773
qusp's Avatar
ok i'll get this question out of the way for the dps600 owners. since we have no ability to ramp the voltage up with these supplies for first turn on; what is the best way forward in your opinion mate?
confirm functioning power supply
test amp without fets installed and set bias on the pot this way? not to full bias, just to say 200mA
build a low power, lower voltage linear supply and use this to test and adjust bias, before replacing with the dps600
all of the above?
Old 9th July 2012, 01:21 PM   #1774
qusp,
I was just re-reading the build instructions from opc and remembered your post from earlier today!
If you have a variac, or even a low voltage supply (say +/-20V) then start with that. Turn the bias potentiometer FULLY CLOCKWISE TO START. This sets the bias at a minimum, which is what you want during startup.
Slowly bring up the power supply while monitoring the current to the mosfets and the voltage of the supply. Stop when you get to +/-20V. If all is well, there should be little or no current flowing through the mosfets with the bias pot turned all the way down. If all is well, start turning the bias pot counterclockwise while monitoring the current. Start with an initial target of 100mA.
Since Owen says if I'd be tempted to build with the DPS600 straight up unless you have it ready to go off hand?
The above passage comes after mounting the mosfets in the build guide so I'd stick them in.
Old 9th July 2012, 01:58 PM   #1775
qusp's Avatar
yeah i've seen that passage, I read the guide when doing the first half of the build.
I probably will do that, but just start with the bias all the way down so the fets arent seeing any current. I could pretty easily come up with a linear unregulated supply to test, hell I could use 2 of opcs little supplies.
its just starting up with an amp untested and with a supply that could just about vaporize the fets...well... i'll have my blast shield (tea tray) at the ready I think and flick the switch from across the room
Old 9th July 2012, 02:41 PM   #1776
Originally Posted by AP2 View Post
Hi all,
..Well, just a sign of life
18 DPS-600 are ready then ship Monday.
I follow GB list criteria for start ship.
today later i return in office for packages and ticket, create photos and put in thread.
Rest of dps-600 need only diode(on regulators) and heatsink , I think two days.
Any news on this Roberto?
Please don't forget that mine go in the same package as qusp's.
Old 9th July 2012, 03:03 PM   #1777
qusp's Avatar
indeed, seems to be the end of the day over there now …
tell me some good news mate?
Old 9th July 2012, 07:45 PM   #1778
AP2 is offline AP2  Italy
Banned
foto at yesterday night (sorry for filter on camera).
Also,new dps-600 and 500/S from production arrived.. i show one just for dimension compared with dps-600.
Qusp & hochopeper is not in photo, package closed with all in side, as qusp know.
In this moment, all package are in deposit of MDI (UPS collect from it).
I'm in lab /office.
today i assemble other two, then start 20 total.
@Richard ok for address change.
for bias, start with (trimmer on low value on lme), switch on and set bias you need.
Remote control tested ok.
I removed led connection from switch as old i show, now led moved on 10 pin connector. (it is controlled by startup and UVLO function) so, light switch off fast when turn-off (independant of remote control use).
I'm sure tomorrow have ticket on web with collected info.
regards
Old 9th July 2012, 09:10 PM   #1779
looking good
Was thinking of getting a bench supply for initial testing, but I'm gonna build up two of OPC's supplies and use those befor hooking-up the dps-600s.
Old 9th July 2012, 11:28 PM   #1780
Thanks Roberto!
@BuildMeSomething, the load on the LME is low enough you can run multiple amps from a single of opc's regs.
Marriage from "ZEN" - and ordinary class AB topology about HCA - why not realized ?? tiefbassuebertr Pass Labs 2 4th January 2014 04:52 PM
X-Amp (LME49830 + Exicon Lateral Mosfets) danfo098 Chip Amps 28 14th October 2013 04:05 AM
"CA-10", new Single Ended Power amp Device based on Aleph or ZEN ? tiefbassuebertr Pass Labs 1 29th September 2010 06:55 PM
Compound Lateral FET for higher power Class AB amp. Mooly Solid State 17 22nd August 2010 02:13 PM
Improvments to "Tube Headphone Amplifier/Preamp with Relay-Based Input and Power Swi" kipman725 Headphone Systems 4 17th August 2009 06:12 PM
Copyright 1999-2017 diyAudio
