"The Wire AMP" Class A/AB Power Amplifier based on the LME49830 with Lateral Mosfets - Page 128 - diyAudio
Old 17th May 2012, 07:45 PM   #1271
Originally Posted by pieter t View Post
So you agree that the SMPS has no inherent advantage over a quality linear supply, am I right?
Uh oh - better start sending out mass emails to all those engineers selecting SMPS then...
Old 17th May 2012, 07:48 PM   #1272
No, I mean technical advantages, not economical advantages (price; weight; volume).
Old 18th May 2012, 07:11 AM   #1273
lolo is offline lolo  France
lolo's Avatar
it does seem like a fight for principles..
Old 18th May 2012, 09:44 AM   #1274
Unhappy smps GB
Hi everyone,
Sorry to say but I'm going to have to withdraw from the GB for the smps... nothing to do with the resent discussion, just I'm about to sell my apartment and am packing things away etc.
I'm hoping to get a place with enough room for a dedicated home cinema / listening room
Listening with Gusto!
Old 18th May 2012, 10:04 AM   #1275
Banned
Good luck with the move, BMS.
Old 18th May 2012, 01:08 PM   #1276
just another
wintermute's Avatar
Guys lets not get personal here. Perhaps if a stalemate has been reached take it off line or agree to disagree.
Any intelligence I may appear to have is purely artificial!
planet10 needs your help: Let's help Ruth and Dave
Old 18th May 2012, 01:23 PM   #1277
npdot is offline npdot  United States
Default Early results from the bench
After correcting the orientation of Z1 so that the LME is not on continuous mute, I got the following preliminary test results.
Test 1:
PSUs: LME +/-65V regulated; OPS +/- 50V monitored & controlled
Output: 30Vrms @ 8ohm @ 1KHz (1Vrms below clip)
THDN: 0.003%
Test 2:
PSUs: LME +/-50V regulated; OPS +/- 50V monitored & controlled
Output: 28.8Vrms @ 8ohm @ 1KHz (1Vrms below clip)
THDN: 0.003%
Test 3:
PSUs: LME +/-65V regulated; OPS +/- 60V monitored & controlled
Output: 33.5Vrms @ 8ohm @ 1KHz (1Vrms below clip)
THDN: 0.004%
Test set: HP339A; two HP6294A (for LME PSU); 72K uF caps per rail monitored and adjusted by variac (for OPS).
Observation: test 1 Vds = 7.6V peak vs. test 2 Vds = 9.3V peak => 1.7V difference
Comment: a) I am very please with the performance of the amp. Hats off to Owen. b) I am also convinced that the separate, higher LME supply is of value for several reasons, but it looks like reducing the voltage drop accross the output device is not of significant value.
What are the rest of you finding?
Old 18th May 2012, 01:34 PM   #1278
The supply voltages limit the peak output voltages from the amplifiers.
An audio replay system, rarely reaches these peak output voltages. We generally design our systems to avoid clipping in normal use.
The result is that the only time that our amplifiers get near to clipping and thus use up that PSU voltage capability is for short term transients. By definition, these transients exist for short periods of time and thus place very little demand on the long term capability of the PSU.
It's the stored charge in the medium and high frequency decoupling that supplies the current for the short term transients.
For these reasons small variations in the choice of PSU voltage at the design stage will have little effect on the audio performance heard from the speakers.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 18th May 2012, 01:45 PM   #1279
Andrew,
I basically agree, but at the same time I am afraid that your remarks will restart the power supply discussion, and I don't think that's a good idea....
Old 18th May 2012, 01:51 PM   #1280
I was replying to a request
I am not trolling, if that's the correct word.
regards Andrew T.
Marriage from "ZEN" - and ordinary class AB topology about HCA - why not realized ?? tiefbassuebertr Pass Labs 2 4th January 2014 04:52 PM
X-Amp (LME49830 + Exicon Lateral Mosfets) danfo098 Chip Amps 28 14th October 2013 04:05 AM
"CA-10", new Single Ended Power amp Device based on Aleph or ZEN ? tiefbassuebertr Pass Labs 1 29th September 2010 06:55 PM
Compound Lateral FET for higher power Class AB amp. Mooly Solid State 17 22nd August 2010 02:13 PM
Improvments to "Tube Headphone Amplifier/Preamp with Relay-Based Input and Power Swi" kipman725 Headphone Systems 4 17th August 2009 06:12 PM
Copyright 1999-2017 diyAudio
