Old 9th May 2012, 11:34 AM   #1081
Can we have comparable test results for a linear PSU+Amplifier combination, so that we can reach our own conclusion on which compromises we want to accept?
Old 9th May 2012, 11:45 AM   #1082
AP2 is offline AP2  Italy
Originally Posted by AndrewT View Post
This abominable behaviour completely rules out this PSU for any situation where mains power could be interrupted before it reaches the household distribution board.
For any SMPS PSU to behave like this is plain and simple "BAD DESIGN"
You've read the previous posts, or come with the usual blah blah ..?
the failure to restart it happens after I changed the connection of a resistor (I did not notice the defect using the remote control, which is perfect) (I have not tried to unplug the AC cable after last modify... I'm sorry)
yes, you and some other it will take 10 years to create this compact SMPS ..just have bad design
Old 9th May 2012, 12:03 PM   #1083
You released an SMPS specifically to work with this amplifier.
The PSU as supplied fails to operate properly.
Do not try to excuse that bad operation.
You designed it badly for the duty you supplied it for.
Old 9th May 2012, 12:05 PM   #1084
BTW,
I know my limitations.
Just one of many is designing SMPS.
I will never try to compete with you in designing any SMPS.
Old 9th May 2012, 12:08 PM   #1085
Please Owen, it is very simple replace resistor connection in first smps i sended. switch on and disconnect ac cable. you see led (it reflect voltage in primary side) switch off clean (no re-start occur).
thank
regards
Old 9th May 2012, 12:16 PM   #1086
I not release this smps..i sended to Owen for adjust it on this amplifier.
this dps-400 creted in 2005, usefull for D class, then problem is in startup with bias current >150mA related this amplifier.
Obvius that have adeguate performances even it is limited to 150w amp.
and is not comparable with other smps for...lamps
Old 9th May 2012, 12:24 PM   #1087
Do not make excuses.
You supplied the SMPS for a specific amplifier.
The test result is abominable.
Old 9th May 2012, 12:28 PM   #1088
opc is offline opc  Canada
opc's Avatar
AndrewT:
AP2 is correct in stating that I am working with an engineering sample, and in all fairness to him, the previous iteration of the DPS-400 he sent me did not have the shut-down problem and did manage to start-up with 400mA of bias.
It seems these are the two biggest issues for people, so in the interest of moving this along I'll change the resistors on the board when AP2 sends instructions and I'll re-test to verify that the start-up and shut-down both work properly.
AP2:
Please send me very specific instructions on exactly what to change, and I'll take a crack at it today providing I have the parts on hand.
Owen
Old 9th May 2012, 12:31 PM   #1089
Sorry, what are the tests abominable?
I have no interest except to convince you. just to prove your pointless blah blah ... I'm not wrong in this project (create in 2005,not now).
I really hope Owen can prove that the defect is not part of this original SMPS
Please, in old dps-400, you have solder an resistor on bottom of pcb. remove it and assemble at original in top of pcb (see top layer white). value is 100-150K and try.
Old 9th May 2012, 12:41 PM   #1090
post1079 quotes the test result from post1075.
X-Amp (LME49830 + Exicon Lateral Mosfets) danfo098 Chip Amps 27 31st December 2012 12:56 AM
Marriage from "ZEN" - and ordinary class AB topology about HCA - why not realized ?? tiefbassuebertr Pass Labs 1 18th January 2011 10:51 PM
"CA-10", new Single Ended Power amp Device based on Aleph or ZEN ? tiefbassuebertr Pass Labs 1 29th September 2010 06:55 PM
Compound Lateral FET for higher power Class AB amp. Mooly Solid State 17 22nd August 2010 02:13 PM
Improvments to "Tube Headphone Amplifier/Preamp with Relay-Based Input and Power Swi" kipman725 Headphone Systems 4 17th August 2009 06:12 PM
Copyright ©1999-2013 diyAudio
