Self load invariant supply voltage
Old 19th September 2011, 09:12 AM   #1
raymondo is offline raymondo  United Kingdom
Default Self load invariant supply voltage
Hi
I recently built a douglas self invariant amp for a friend using a couple of pcb s from the signal transfer company. Very high quality boards and excellent service btw.
Had it running of a bench supply for testing now have it running off a large toroid and simple rectified supply with x2 22000uf caps (stuff I had lying about). My issue is the supply is just a little hot for the design - self recommends a maximum of +-45V , but my supply is 48.5V. Im wondering if there is a nifty/simple way to drop the rails to 45V or lower without affecting performance? It also doesnt seem to sound quite as good with the higher rails (I had it running of 30V before), maybe its distortion performance is affected. It has some serious clout though !
Self load invariant supply voltageHide this!Advertise here!
"Load-invariant", LTspice and ringing Khron Solid State 18 5th May 2011 01:19 AM
Voltage spikes under load tstitans Power Supplies 3 13th August 2009 02:01 AM
PS voltage without load duke_tj Power Supplies 5 16th September 2007 06:27 AM
No Load Voltage on Zen V4 Power Supply vsr123 Pass Labs 13 5th May 2003 04:10 PM
Amplifier Construction(Load Invariant) Xavier Solid State 8 28th September 2001 03:33 PM
