#11 |
Would it be good to put capacitor accross bases of transistor drivers to lower distortion?
#12 |
Nice to see you here, Wim. I have long admired your work.
As it happens, I'm working on a hybrid too, and just like you, have long considered the 5965 as it has ideal mu and rp for the voltage stage. The SS buffer is done; it does use nfb, but has loop gain of around 50dB, easily manipulated. The ideas behind it are quite similar to yours! Groetjes, Hugh |
#13 |
SS buffer with nfb is exactly what I am looking for. Would you mind sharing schematics or can you be please so helpful and point me to another schematic/idea?
Thank you. |
#14 |
Enclosed the document I made regarding the Tubecad Aikido driver stage in combination (ECC83/82) with the Nishiki powerstage. This docement also mentiones the values for the 5965 tube.
Wim
n/a |
#15 |
And for those who have interest, I do have still some professional made PCB's of the Nishiki powerstage, see enclosed photo. I can offer the PCB for just 10 euros, for stereo you will need 2 boards.
Wim
n/a |
#16 |
Can I lower emitter resistor in output stage from 0.22 Ohm to 0.1 Ohm to have better damping factor without any stability problems?
Thanks. |
| Nishiki hybrid amp | Tyimo | Solid State | 87 | 6th May 2013 01:23 AM |
| Genuine 2SC5200 ??? | Graham Maynard | Solid State | 109 | 30th November 2011 08:23 PM |
| 2sc5200 and 2sa1943? | adobetoo | Solid State | 3 | 27th March 2011 08:46 AM |
| 2sc5200 | sdman | Solid State | 15 | 12th September 2010 05:59 AM |
| fake 2sc5200? | xeclipse | Solid State | 3 | 25th June 2010 03:43 PM |
