Old 18th September 2011, 05:59 AM   #1
Default SIMPLE BUT EFICIENT AUDIO AMPLIFIER !
Hey fallks,i want to build a simple yet efficient power amplifier , one that i would use for my room witch is not so big,and using the amp. with high SPL speaker boxes . Just read and read and i just can seem to take a decision on wath to buil,i want it simple , and not a big power for it ! Can someone help ? Thanks !
Old 18th September 2011, 06:50 AM   #2
Mooly's Avatar
So much depends on your abilities and construction skills... and on what you call simple.
Would you make your own PCB's for example ? or do you want something that has PCB's available to buy.
Sounds to me like you might be better off with something like a chip amp (LM3886 or similar) built on boards that are readily available.
A simulation free zone. Design it, build it, test it.
Old 18th September 2011, 07:36 AM   #3
astankov's Avatar
Yeah chip amp will be good for you. In transistor amps simplicity (of the schematic of course not in building) is in negative proportion with efficiency.
Old 18th September 2011, 07:47 AM   #4
tomchr is offline tomchr  United States
tomchr's Avatar
If you don't mind a little tricky soldering, something like the ADAU1592 would be a good candidate.
If you want easy, plug&play I'd probably go with an LM3886.
~Tom
"50 % of the game is mental and the other 50 % is being mental. I've got that part down, no problem."
http://www.neurochrome.com/audio
Old 18th September 2011, 02:31 PM   #5
Default check this site
tried and tested.
L.E. Amplifiers
Old 18th September 2011, 05:27 PM   #6
L.E Amplifiers,
L.E Series2 and landmark?
Old 18th September 2011, 05:57 PM   #7
Thank you all , yes i have build allot of pcb-s by hand all kind of methods. I build my electronic "gadgets" from scratch,from single or double sided ,from permanent marker to laser printer,feeryc chloride etching,1mm drilling,soldering,etc. but im out of ideeas !
Old 19th September 2011, 07:14 AM   #8
Default with a given pcb layout and parts list & with instruction....
Originally Posted by Mhavskie View Post
L.E Amplifiers,
sure this will help a lot.
Simple Audio Amplifier For Learning Purpose circuitcity Solid State 2 14th August 2010 12:05 PM
Simple Power Supply for Audio Amplifiers. (Why? This is for audio) AP2 Power Supplies 10 30th March 2010 12:02 AM
simple Amplifier? technics Solid State 38 31st March 2008 11:36 PM
simple amplifier bigspeakers Chip Amps 4 23rd June 2006 12:34 PM
need a simple amplifier DrSplodge Everything Else 12 28th July 2004 06:49 AM
Page generated in 0.17641 seconds (61.08% PHP - 38.92% MySQL) with 10 queries
