Well..... there are 2 ways (at least what i know) of attaching transistor, which need heatsink. (i) Direct solder to pcb (ii) mounted on heatsink, connect to PCB through wire
So, skip the advantages and difference. What is their separate precaution need to be taken, especially heatsink mounted ? What i know is that the wire connect to PCB need to be as short as possible, but how long is permissible ? (well.. limits Could i twist the 3 terminal of wire together, or crossing ? ( Does getting a conductive material wrap around the wires will help ? (minimize distortion by electromagnetic radiation) |
#2 |
Leads to output devices should be as short as possible. To not do so is asking for trouble with unwanted oscillation and stability problems.
If you must use wire then keep it all separate and no shielding.
------------------------------------------------------- A simulation free zone. Design it, build it, test it. |
#3 |
what is the typical length when you say short ? is 5cm long ? or better not to use this method ?
Well.... I haven't got my heatsink, so i don't know how i'm going to attached to it, using wire(more flexible) also seems to make the amp prone to unstability, any other method i could use, and also provide me the flexibility of choosing heatsink ? |
#4 |
If it's for the amp in your other thread then you will probably be OK as the design of that amp lends itself to being a stable design. 5cm isn't too bad but make it as short as possible.
#5 |
yeah yeah, its for DX Trust, uncle carlos' amp (aka. Destoryer)
Guess i will leave it until i have the heatsink in hand. |
| heatsink mounting Q | woodturner-fran | Pass Labs | 6 | 15th April 2008 09:00 PM |
| Mounting a Heatsink | Bigman | Chip Amps | 8 | 13th December 2007 02:00 PM |
| mounting of outputs to heatsink | bigpanda | Solid State | 10 | 27th April 2006 10:44 AM |
| Help - Mounting transistor to heatsink | vsr123 | Pass Labs | 10 | 17th April 2003 11:43 AM |
| Heatsink mounting. | JoeBob | Solid State | 3 | 21st January 2002 02:51 AM |
| Page generated in 0.08839 seconds (69.42% PHP - 30.58% MySQL) with 10 queries |
