Old 17th September 2011, 04:49 AM   #1
popilin is offline popilin  Argentina
popilin's Avatar
Default 100 Watt Class A Power Amp
Has anybody the complete article of Norman Thagard
"Build a 100-Watt Class-A Mono Amp"
Published in Audio Magazine January 1995-February1995-March1995 ?
I have only the first one, I never could obtain the second and third here in my country.
Thanks.
Old 17th September 2011, 05:26 AM   #2
formula 22's Avatar
Hi !
Check the forum threads here.
Old 17th September 2011, 06:20 PM   #3
popilin's Avatar
I had allready check, the only I could obtain was
Coulomb 28th July 2002
"The Pass/Thagard project was a 100 Watt class A Amplifier published in Jan, Feb and March of 95. I will scan the schematic and post the PDF Monday night in Pass Forum under Pass/Thagrad thread."
Coulomb 29th July 2002
"I have attached a PDF of the schematic for the CLASS A 100 Watt Amplifier section. I do have all three articles available, but thought I would start with this schematic to see if there is any interest."
I have the schematics, but parts list is in the next article that I haven't
Old 17th September 2011, 08:05 PM   #4
Send a message via Skype™ to hotrodmaniac
Popilin
Here is the parts list that you needed. I have the complete set of articles
but I will need to scan them in a lower resolution. reply if you still need
them.
Jim Messer
Old 17th September 2011, 10:26 PM   #5
popilin's Avatar
Hi hotrodmaniac, (Can I tell Jim?)You are a Master!!!
16 years and now I have the parts list, Thanks a lot!!!
I have in my collection the Audio Magazine and a piece of newspaper with a picture of the Space Shuttle "Atlantis" with Dr. Thagard inside, but the parts list...never until today.
Thanks again, when You have the time, could You scan the Heatsink details?
Best Regards from Argentina
Popilin
Old 17th September 2011, 11:43 PM   #6
jaycee is offline jaycee  United Kingdom
100W class A? I hope you live somewhere cold and with cheap electricity
Old 18th September 2011, 12:17 AM   #7
The one and only
Nelson Pass's Avatar
The Pass/Thagard amp article is posted under articles at
Pass Diy
in two parts.
That one was called the A75. I recall that Norm later published
one solo.
Old 18th September 2011, 03:41 AM   #8
Popilin
I didn't mean to take so long to reply. I had a little bit of trouble finding all
the articles as I had removed them from the magazines to scan them previously. I would suggest building the Pass F-5 instead. The project that I am sending you is a good learning tutorial. This DIY forum is loaded with good information and helpful members. When the Norm Thagard class A 100W amp was published it was pre-DIY for me. Good luck!!!
Jim Messer
Old 18th September 2011, 03:45 AM   #9
Popilin
one last attachment.
Jim Messer
Old 18th September 2011, 03:52 AM   #10
Popilin
Somehow I messed up the attachments.
Jim Messer
Sure electronics 4*100 watt @ 4ohm, TK2050 D-class Audio Amplifier Board aquapiranha Class D 3 30th May 2011 11:06 PM
JCM 900 100 Watt Power Trans Specs.. DaveMcLain Tubes / Valves 7 19th April 2008 03:41 AM
A 100-150 watt power amp using TIP41-142-147 transistors, how about gaetan8888 Solid State 12 24th April 2007 11:11 PM
FS: 350 Watt Power Amp Module $100.00 Zero Cool Swap Meet 3 27th May 2005 11:37 PM
100 watt amp sepo Chip Amps 3 5th February 2004 05:10 PM
Page generated in 0.11452 seconds (78.94% PHP - 21.06% MySQL) with 11 queries
