Here is a picture of some resistors on this 1979 vintage moving coil head amp from Marcof. Do you think these are carbon film or metal film design? Since this is a high gain (34 dB), very low signal device, I was thinking it could benefit from a lower noise resistor. Noise here is further amplified by the phono section amp, then the pre-amp, and finally the power amp. Metal foil would seem to be the best but is not available in correct values, and metal film would appear to be the next best choice.
I'm thinking the beige body color and the vintage would suggest carbon film??
#3 |
They are 1% , likey metal film
#4 |
The double width last band is the give away. Blue body color is usually meant to mean flame proof. As modern metal film resistors do not contain carbon they are flame proof. Double width tolerance band means metal.
#5 |
Texas Components will make Vishay foil resistors in any value and tolerance that you need. Price may be higher than you are willing to pay however. Regards
Evil looms. Cowboy up. Kill it. Get Paid. |
#6 |
Thanks for the quick responses. On a check it appears 1% carbon film resistors are now about as common as hen's teeth. Anyone know if it was the same 30 years ago? If so along with the other clues it would seem virtually 100% certain these are metal film. Thought there might have been a cheap upgrade to reduce noise, but it appears not.
#7 | |
#8 | |
Marcof PPA-1h Circuit Drawing Yes, there appears to be differences in the types of metal films. See the figures near the end of the article below. However, finding the good ones in small quantities seems to be another matter. Sources for the RN65? Is that just a military designation for the Dale CMF? Resistor Current Noise Measurements |
#9 |
#10 |
Why would anyone do carbon-film in 1%? Take out one R and get a metal-film of the same resistance. Attach wires, measure at room temp. Put in oven to about 100 Deg.C, measure again and compare resistance. The mf should have less than 10% drift of the cf. E
| Capacitor Replacement Opinions? - Marcof PPA-1h MC Amp | Ron AKA | Solid State | 0 | 27th August 2011 06:44 AM |
| metal film resistors or carbon? | leitmo | Tubes / Valves | 2 | 28th June 2008 10:14 AM |
| Res Survey:....... Carbon film ...or... Metal Film ...............?? | nina | Chip Amps | 13 | 14th April 2005 12:46 AM |
| Carbon film vs metal film resistors in a stepped attenuator? | G | Tubes / Valves | 17 | 22nd August 2004 12:22 AM |
| Metal film resistors or carbon film in a tube amp? | G | Tubes / Valves | 220 | 31st March 2003 01:57 PM |
| Page generated in 0.09543 seconds (84.66% PHP - 15.34% MySQL) with 10 queries |
