Problem with 80W mosfet amplifier - help me please Problem with 80W mosfet amplifier - help me please - diyAudio
Old 13th September 2011, 07:10 PM   #1
Temptation is offline Temptation  Malaysia
Post Problem with 80W mosfet amplifier - help me please
Hi
Can anyone help me with this circuit??
and here's the PDF version of it :
888.pdf - 4shared.com - document sharing - download
I bought this circuit as a kit but it has some hiss and noise(when no music is played) that I want to remove them from my speaker
here's the original version of this circuit :
and its site :
Simple Circuits MosFet Amplifier IRF9530 IRF530 | DIY Audio Electronic Surround Sound Home Theater System Techno News
can anyone help me??
Old 13th September 2011, 07:34 PM   #2
NMOS is offline NMOS  Germany
NMOS's Avatar
in my opinion poor design
IRF 9630 / 630 are not really symetrical
use QUASI NMOS 300/500 with N Channel output devices
no hiss and HIgH END Sound
Old 13th September 2011, 07:50 PM   #3
Hi NMOS
So all these noise and hiss is because of output Mosfets ??? are you sure????
Can you tell me the exact part name of this "QUASI NMOS 300/500"???
Old 13th September 2011, 10:05 PM   #4
badcompany2all is offline badcompany2all  United Kingdom
Can anyone help me to remove these noises?
Old 14th September 2011, 04:44 AM   #5
anyone?
Old 15th September 2011, 05:47 PM   #6
east electronics is offline east electronics  Greece
east electronics's Avatar
define if its a noise or a hiss .... hiss and noise are diferent things
hiss might be produced from a low quality IC also from poor filtering on the ic ( c1 c2 ) you might try some other alternative IC than the tl
first of all you need to try your amp with input shorted to ground to make sure that his or noise doesnt come from the source or the wiring
if noise is heard like 50 HZ you have a ground loop issue
SERVICE ΕΝΙΣΧΥΤΩΝ ΚΑΙ ΙΑΠΩΝΙΚΩΝ ΜΗΧΑΝΗΜΑΤΩΝ ΗΧΟΥ www.eastelectronics.gr
Old 15th September 2011, 06:12 PM   #7
digits is offline digits
digits's Avatar
I would start with a 100nf cap from pin 4 to 7 on the IC, right on the chip.
Old 15th September 2011, 08:11 PM   #8
BrianVG is offline BrianVG  Belgium
Also, you can add a 'Boucherot network'
A boucherot cell (or Zobel network) is an electronic filter, used in audio amplifiers to damp high frequency oscillations that might occur in the absence of loads at high frequencies. Named after Paul Boucherot a boucherot cell typically consists of a resistor and capacitor in series, that is usually placed across a load, for stability.
It is placed at the output of the amp and then you connect your speaker.
Also make sure that your ground-cables are as short as possible. They can work like as an antenna and pick up noise/occur oscillation.
FET fanatic
Old 15th September 2011, 08:47 PM   #9
wahab is offline wahab  Algeria
An experimental design from ELEKTOR whose typography is instantly recognizable..
The site doesnt seems to credit this review , though...
Old 17th September 2011, 06:58 PM   #10
thank you all for your suggestions
At first I thought this hiss sound is producing from my amp (when I open this thread) but when I checked my computer's sound card with my headphone I realized that this hiss is from my computer
I ask a few friends and they said that I should change my sound card.
I wanna know that is there any way so I can remove this hiss from my computer's output????
My main board is GIGABYTE GA-EP43_DS3L and I'm using its onboard sound card.
If there's no way to remove this hiss from this sound card, can anyone introduce me a good sound card ??(without any hiss or hum or any noise)
Problem with 80W mosfet amplifier - help me pleaseHide this!Advertise here!
80W Hybrid Audio Amplifier! radio Solid State 136 2nd July 2017 08:03 AM
JLH 80w mosfet power amplifier - modifying it Kevinbd Solid State 128 16th March 2017 04:41 PM
Maplin 100W mosfet amplifier - power supply problem HBrunt Solid State 32 3rd December 2013 07:11 AM
One Channel of JLH 80w Mosfet Louder than other foxyb Solid State 2 12th October 2004 01:14 AM
Linsley-Hood 80W mosfet amp Spartacus Solid State 10 16th December 2003 04:55 AM
Copyright ©1999-2017 diyAudio
