Old 13th September 2011, 10:39 AM   #1
Default Feedback Takeoff Point ?
From douglas book :
The exact layout of the feedback takeoff point is criticial for proper
operation. Usually the output stage has an output rail that connects the
emitter power resistors together. This carries the full output current and
must be substantial. Take a tee from this track for the output connection,
and attach the feedback takeoff point to somewhere along this tee.
Do not attach it to the track joining the emitter resistors.
I have attached a DIY Amplifier layout from DX (nice amplifier they design, i like it)
But i have some problem to maximize the layout potential, minimizing distortion problem.
The quote from respectable douglas, using his knowledge to do the best
So the problem here is that i don't know how to identify the feedback takeoff point which HE mention.
Just to confirm, so i should take a tee from the junction between the R7 & R8 (0R33) which in short the point "A" on the right, to the feedback takeoff point ?
Old 13th September 2011, 11:17 AM   #2
DF96 is offline DF96  England
Put a tee somewhere on the line from R7/R8 to C9/C3/R17.
Old 13th September 2011, 11:56 AM   #3
janneman's Avatar
Location: Where Germany, The Netherlands and Belgium meet
I would take it from the pad that has the connection to speaker post.
The idea is to take the feedback from the point that you want to be as linear and low distortion as possible. That normally is the speaker connection.
jan didden
/Another new issue: Linear Audio Volume 3!
Old 13th September 2011, 12:07 PM   #4
This amp has two feedbacks. One comes from the speaker terminal. The other includes DC and comes from before the output coupling cap.
Old 13th September 2011, 12:52 PM   #5
DF96 : haha, thanks for the info, but i really have no idea how to identify those feedback path, anyway to let me learn about it ?
jan didden : what do you mean by 'pad' ? So the tee mention is from speaker post to where ?
So what should i emphasis on douglas' word ? can't really understand fully ^^
Old 13th September 2011, 01:35 PM   #6
Read Doug Self's book?
Old 13th September 2011, 01:43 PM   #7
digits's Avatar
The two A's are connected as the first, and I think the second is that R18, right at the bottom.
Old 13th September 2011, 01:55 PM   #8
thanks for pointing out, digits.
DF96, i only know and get hold of "Douglas Self - Audio Power Amplifier Design Handbook", but its more on amplifier building/designing and not much about those little thingy (he mentioned that in the book foreword too)
Old 13th September 2011, 02:13 PM   #9
Maybe you need to find a book which starts further back. This topic comes up regularly on here so do a forum search.
Old 13th September 2011, 08:35 PM   #10
selim is offline selim  Turkey
Hi guitar89,
If I understand correctly,what Mr. Self means about the feedback takeoff
point is that feedback tries to make an amplified replica of the signal at the
physical point where it is taken.In your case, it would be the (+) terminal
of the output capacitor (6800 uf).Thus, the cleanly amplified signal would
appear at the (+) terminal of the output cap, which is what you want.
Hope this helps.
Cheers
Selim
Which point to connect the global feedback? neazoi Solid State 9 2nd April 2011 06:49 AM
Op point for 6au6/6gu5 in P-G feedback 6550 vanofmonks Tubes / Valves 9 12th September 2010 08:29 PM
Negative feedback take off point fglabach Solid State 12 3rd May 2009 11:29 AM
Benifits of point to point wiring for digital circuit? MGH Digital Source 15 14th September 2006 10:17 PM
Global Feedback Source Point gingertube Tubes / Valves 3 1st August 2005 11:21 PM
Page generated in 0.09586 seconds (83.43% PHP - 16.57% MySQL) with 11 queries
